Personalized Elk and Mountain Sign
jtindall
Post by jtindall »
I have a student making this sign for Christmas and wants to put in an elk. But we can't find one that fits with the size of the sign. Help or any advice?
brandi.pcm
Re: We are trying to copy in an elk
If you could post your file in dxf or svg format you will open up to far more members here who can help you. Only Plasmacam folks can open your pcm file to see what your looking to do.
harrymorley
Post by harrymorley »
I looked at your sign. If the thickness of the border were reduced in width, an elk would fit better . It has to do with scale . I have elk that fit but the scale is wrong . Just keep the size the same but reduce the width of the lettering .
harrymorley
here ya go..this seems to fit better. You can increase the heighth of the bottom area if ya wanna add text some more detail
lisle.pcm
jtindall
Post by jtindall »
Hey thanks for the help. I will try to load as a dxf file. I didn't see that it got saved as a pcm
harrymorley
here it is as dxf
lisle dxf.dxf
