So I have a question. I have several companies that have colored logos and would like a sign made. What is the best way to get them into Inkscape?
I have tried a couple ways but it seems to mess up the font or something else.
Attached is an example, on this one the bottom text is messed up.
Company Logo Import
Company Logo Import
- Attachments
- Capture.JPG (12.19 KiB) Viewed 2993 times
- ConvergeLogo72_copy.jpg (16.23 KiB) Viewed 2993 times
Re: Company Logo Import
I am guessing your doing and auto trace and from what I can see it looks like you are doing everything correctly. The bottom text is very small and an auto trace will never deliver you clean crisp lines when the image or small or resolution is low. In this case the best bet may be to delete the traced text and replace it with the text tool in Inkscape and find a font that is the same or similar. Let us know what you end up doing.
ask them for the original logo design as a starting point, sometimes they are designed in a vector file format to start with, but they ignore that and just use the jpg for their website and stationary but the vector files are key for easy conversation and lossless conversation.....
- ROKCRLER
See if this works for you.
I found their logo and used that to trace.
The smaller font I used text and used Helvetica font.
The ellipses I manually made with ellipse tool.
- Attachments
- ConvergeLogo.svg
- (95.4 KiB) Downloaded 55 times
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
plasmanewbie wrote: ↑Mon Dec 11, 2023 3:00 pm I am guessing your doing and auto trace and from what I can see it looks like you are doing everything correctly. The bottom text is very small and an auto trace will never deliver you clean crisp lines when the image or small or resolution is low. In this case the best bet may be to delete the traced text and replace it with the text tool in Inkscape and find a font that is the same or similar. Let us know what you end up doing.
https://www.myfonts.com/pages/whatthefo ... resultPage https://fontsgeek.com/fonts/helvetica-n ... -condensed
Thank you for your explanation that is exactly what I need.
- tinspark
Best explanation ever David. And without even saying a word.adbuch wrote: ↑Tue Dec 12, 2023 4:23 pmplasmanewbie wrote: ↑Mon Dec 11, 2023 3:00 pm I am guessing your doing and auto trace and from what I can see it looks like you are doing everything correctly. The bottom text is very small and an auto trace will never deliver you clean crisp lines when the image or small or resolution is low. In this case the best bet may be to delete the traced text and replace it with the text tool in Inkscape and find a font that is the same or similar. Let us know what you end up doing.
Anyone on earth can understand that language no matter their mother tongue!!
LOL
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
Hypertherm 45XP-
