Inkscape fonts
Inkscape fonts
I found that the newer Inkscape was not using the fonts from the Windows folder. You can add all the fonts from there by going to preferences under system and find the folder for the their fonts. It is not in the Inkscape floder location. :Sad Then go to Windows font folder, under organize, click on select all, then copy. Move to the inkscale font folder and select paste. I will copy all Windows fonts to that folder and you can not use them in Inkscape. This is the same thing for new fonts you download, just copy and paste. :Like
Re: Inkscape fonts
Tom - thanks for that tip! I'm still using Inkscape 1.2, and am a little hesitant to switch over to 1.3 as members on the Inkscape forum have pointed out some differences and loss of tools that I really don't want to deal with right now. It seems like it wasn't all that long ago that I upgraded to 1.2.2.
Let us know how you like the newest version and if you see any issues or changes that we should be aware of. Thanks for your report about the fonts.
Re: Inkscape fonts
Well David I am not using the new version I am still at 1.2, so your ahead of me. :HaHa :HaHa
I would assume the font info is still the same, as in the past Inkscape did use the Windows font folder. I only noticed it when looking for changes in fonts to use on a project today. :Sad
Re: Inkscape fonts
acourtjester wrote: Wed Sep 20, 2023 7:21 pm Well David I am not using the new version I am still at 1.2, so your ahead of me. :HaHa :HaHa
Tom - I'm also using 1.2 and any font I put into the Windows fonts folder automatically shows up in Inkscape the next time I open it. So apparently my Inkscape version 1.2.2 does use the Windows font folder. I'm not sure why yours should be any different.
djreiswig
Re: Inkscape fonts
Post by djreiswig »
acourtjester wrote: Wed Sep 20, 2023 4:44 pm I found that the newer Inkscape was not using the fonts from the Windows folder. You can add all the fonts from there by going to preferences under system and find the folder for the their fonts. It is not in the Inkscape floder location. :Sad Then go to Windows font folder, under organize, click on select all, then copy. Move to the inkscale font folder and select paste. I will copy all Windows fonts to that folder and you can not use them in Inkscape. This is the same thing for new fonts you download, just copy and paste. :Like
Can't you just change the setting for the folder to the windows font folder instead?
Re: Inkscape fonts
I did not try to change the folder info in the preference, but no reason it would not work, it is just giving a location to look.
Return to “Inkscape”
