Barks and Bubbles sign using Samson router
- Joe Jones
I fired up the Samson today with the router attached, and cut out some lettering for a wooden sign for a new dog salon. The letters need a bit of sanding and additional care before they are primed and painted, and glued to a wooden background to make an interior sign near the front door.
The material isn't really good for this type of project, but it is what I had. I would have preferred to cut out the letters using the laser, or even using sintra board or something more router-friendly. This is what I had, so ...
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
12 Lasers
FREE DesignEdge Training!
Samson 510 & 4x4
12 Lasers
Re: Barks and Bubbles
Joe you may look at different bits to get better results, and another trick is to use sign vinyl as a mask to route through a per painted wood surface.
This is using a bit with a 5.26 degree taper (Caveman) And other techniques,
Last edited by acourtjester on Mon Jul 24, 2023 10:02 am, edited 2 times in total.
- Joe Jones
I can get great results when I use good material. This is that cheap Luan from the big box stores. It is the cheapest thin plywood, and it really isn't good for projects like this.
I would have preferred to use a nice piece of maple or something.
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
I think the letters look great Joe, looks awesome. Definitely would have been a good job for one of your lasers though.
Re: Barks and Bubbles sign using Samson router
Down cut bits work great for thin cheap plywood
Tom - those are some great looking projects! And I like the idea of using the vinyl mask for routing thru pre-painted wood. Which particular bit with 5.26 degree taper are you using? Brand and source please.acourtjester wrote: ↑Mon Jul 24, 2023 9:24 am Joe you may look at different bits to get better results, and another trick is to use sign vinyl as a mask to route through a per painted wood surface.
I very much agree.
"What router bit to use for cutting out plywood?
Downcut spiral router bits
Downcut spiral router bits leave an extra clean surface with the least possible amount of tearout. Why do you want a downcut router bit for plywood? Because downcut router bits produce a really clean surface with a scissor-like shearing action."
Here are some of the bits
This is the taper bit like the one I use, of all the bit sites I have stored I cannot fine the exact one. the site had many slightly different tapers, as stated I used a 5.26 degree taper.
https://www.cncbits.ca/product/ultra-fi ... ose-0-5mm/
compression type both up cut and down cut on the same bit, these bits give you the best of both worlds of up and down cut.
https://bitsbits.com/product/425-cm250-sf/
video on some use of the tapered bit
many other tapered bits here
https://www.amazon.com/s?k=tapered+ball ... _sb_noss_2
Tom - thanks for the information on the bits and the video! I will check them out.
- Joe Jones
My neighbor finished the sign. Lots of work, sanding the letters, and laying out the pieces to match the business card.
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
Looks great, makes for a happy customer, I give it 4 ruffs
- Joe Jones
I will order a few from Amazon and see how they perform. Thanks!
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
Turned out awesome Joe. Well done!
- Joe Jones
Thanks. I did not do the finish work. That is my extremely artsy-crafty neighbor! She has the patience of Job. I am not good at finish work. I don't have the patience to pay close attention to fine detail on things that don't really matter.
Franklin, KY., USA
Samson 510 & 4x4
12 Lasers
Samson 510 & 4x4
12 Lasers
