software update
rock4xfab
software update
Post by rock4xfab »
Can I just download the newer sheetcam and transfer the license or do I need to edit my post processor for floating torch height also. what is the best procedure. FYI I lost all my Toolsets when the computer battery died. Im thinking I may have also lost the correct height setting in the post processor also. I do know what it was but what else is required to revup to a newer version
djreiswig
Re: software update
Post by djreiswig »
What version do you have? If you have TNG & want to update to the latest version, you can use the update option in the help menu. Your toolset should remain the same. If you edited your post, it should also remain. If you don't have TNG, I don't think your license will work with the newer version.
rock4xfab
Re: software update
Post by rock4xfab »
Yes I have TNG 2.06 Les sent me the last release that would work on XP. 6.1.28, the computer is not on the NET so I had to drop the new file on via flash drive.
rock4xfab
Re: software update
Post by rock4xfab »
Sheetcam, and tool sets all updated!
ROKCRLER
Re: software update
Post by ROKCRLER »
Heck yeah!... get to cuttin'! :beer:
4x8 Dynatorch
PM85
~Mo~
sonbakler
Re: software update
Post by sonbakler »
rock4xfab wrote: Sun Jun 25, 2023 5:44 pm Sheetcam, and tool sets all updated!
:Like :Like
rock4xfab
Re: software update
Post by rock4xfab »
Cutting parts as I dial stuff in
ROKCRLER
Re: software update
Post by ROKCRLER »
Looks good man, glad you got it running again.
4x8 Dynatorch
PM85
~Mo~
rock4xfab
Re: software update
Post by rock4xfab »
thanks..
Re: software update
Rock4Xfab nice looking hole cuts but I think you should work on the lead in/outs of the first image. Maybe change the type of cutting for the inside and outside offset plan.
rock4xfab
Re: software update
Post by rock4xfab »
The part was posted out as no offset. I was having an issue with some overlapping contours and Sheetcam was having a fit so I said fuck it just cut. I have since fixed the drawing and it cuts fine. Again this was starting up a machine I built over 14 yrs ago so I am dusting off grey matter and cobwebs remembering all the stuff.
Re: software update
Good plan have fun
Return to “SheetCam”
