PlasmaCam's 4x8 Plasma Table
- Joe Jones
When they finally break down and sell a 4x8 table, I wonder what they will call it?
After all, there are only a FEW pieces that need to be made. They already have the 4x4 frame pieces, and the center legs for the 510 table, and the 4x4 end frames, and the 4x4 rails, and the 4x4 'Y' grate slats, and the 4x4 gantry.
All they need to do is make the 'X' grate slates for a 4x8 instead of a 5x10, and shorten the two center brace plates of the 510 table to accommodate a 4x8 format. It would seem to be a no-brainer. Not EVERYONE has the room for a 5x10 table.
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
16 Lasers
FREE DesignEdge Training!
Samson 510 & 4x4
16 Lasers
Re: PlasmaCam's 4x8 Table
Trying to come up with something funny and witty but drawing a blank. None of the current names relate to each other at all. Let's hear some suggestions and have a vote
- Joe Jones
I just wish PlasmaCam would sell ALL of the table components, so we could buy the frame extensions and additional legs, etc. I would love to convert my 5x10 into a 5x20, but PlasmaCam will not sell the factory frame and leg components, and they will not even TRY to offer custom wiring harnesses for people who want to remove that STUPID boom arm and put drag chains along the X and Y axis of the table.
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
Samson 510 & 4x4
16 Lasers
Well I can see why they don't want to entertain custom requests, or retrofit parts, it's time consuming and creates tech questions which makes things unprofitable. It would be a great service to their huge client base though. So what's your name suggestion for the new 4x8 from Pcam if they ever do it...I wanna hear this...
- Joe Jones
Nothing would need to be retrofitted. They already HAVE the parts. Two 4x4 tables could be easily built into a 4x8 by simply providing the center legs and swinging boom arm of the 510, and the appropriate cross braces and grate slats. They would also need to provide the gear racks for the 510 rails, to span the gap between the two 4x4 rails butted together.AREA wrote: ↑Mon Dec 26, 2022 2:09 pm Well I can see why they don't want to entertain custom requests, or retrofit parts, it's time consuming and creates tech questions which makes things unprofitable. It would be a great service to their huge client base though. So what's your name suggestion for the new 4x8 from Pcam if they ever do it...I wanna hear this...
What to name a 4x8 table ... How about "The PlasmaCam 48"? The "510" is a 5x10, so why wouldn't the "48" be a 4x8?
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
Samson 510 & 4x4
16 Lasers
The the table parts are a bolt on, the torch boom removal would be a retrofit. All I am saying is that they sell table parts, customer takes machine apart, puts it back together, now has issues, calls tech support. It will happen, they know that, and I am sure that is one of a few reasons they don't do it.
Yes, PlasmaCam 48 sounds good
- rdj357
Delilah 048
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
- Joe Jones
There is ZERO difference between bolting together a 5x10 or a 4x8. Some of the parts are a foot shorter. That is the ONLY difference.AREA wrote: ↑Mon Dec 26, 2022 3:50 pm The the table parts are a bolt on, the torch boom removal would be a retrofit. All I am saying is that they sell table parts, customer takes machine apart, puts it back together, now has issues, calls tech support. It will happen, they know that, and I am sure that is one of a few reasons they don't do it.
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
Samson 510 & 4x4
16 Lasers
- ben de lappe
Hmmmmmm.... Clearly you've put a lot of thought into this. Any chance you whisper sweet nothings into your machines data port on those long lonesome nights in the shop?
- rdj357
Maaaaaayyyyyyyyybe? I never, ever mention hair clippers though!ben de lappe wrote: ↑Mon Dec 26, 2022 11:43 pmHmmmmmm.... Clearly you've put a lot of thought into this. Any chance you whisper sweet nothings into your machines data port on those long lonesome nights in the shop?
Robert Johnson
Re: PlasmaCam's 4x8 Plasma Table
I did it in just a few hours,
Needed a little bit of 3-inch angle
Drew up center leg
both side rails with racks from plamascam
less than a day of labor
And I'm sure would cost a lot more from plamacam
Hypertherm 65
Hypertherm 65
- Joe Jones
NICE job on the exhaust system!
I am guessing the additional 1/4" width of the rails was not an issue?
Did you use the 4x4 gear racks, or did you change to the 510 gear racks for the extended rails to achieve the full 8 feet of X travel? If you used the 4x4 gear racks, how did you deal with the gap between them?
Did you buy the CSB Customizable Size Upgrade for your DesignEdge software?
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
Samson 510 & 4x4
16 Lasers
Nice job Rex! What you did in a few hours would probably take me a few days or more. I guess I work slow.
