No Outputs for air scribe relay or plasma
Hello, I relocated my shop and had my table dialed in nicely. I moved shops and 6 months later I have no Aux output for the Air Scribe and no torch signal either. I can hear the relay for the air scribe but it will not put out voltage.. ?? any help would be great
Re: No Outputs
I would check for loose cables or connections which may have occurred during transport.
Re: No Outputs
David is right it's that old thing what did you do just before it quit working.
Re: No Outputs
So if you hear the relay clicking then the output from the controller is working and triggering the relay to open/close so the output you are referring to that is missing is the voltage output from the relay. This shouldn't be too hard to track down. What feeds that relays out put circuit? Trace that back to it''s power source and you may find something is not hooked up correctly.
Re: No Outputs for air scribe relay or plasma
Just FYI. The AUx AC outlets run off a separate AC cord with its own breaker . The Main Ac tot he controller doe snot power those outlets .
If you moved shops, something probably came loose. I moved shops about 2 miles once and every PV needed cards and ram reseating
I can hear the relay clicking and when either a multi meter a test lamp or the 120V relays there is no voltage output. I did actually find three loose wires and I was excited as I thought I found the issue.
