Accumove 2 controller no response
Not getting connection from Ethernet from accumove 2. It’s works fine for over a year. Then today not getting anything. Have any of you had this happen?
- SegoMan DeSigns
Re: Accumove 2 controller no response
Have your tried cleaning all connections with a contact cleaner or a different patch cable?
Yes I have went through all the normal steps. Mine doesn’t have indicator lights on the Ethernet port, but the pc is not showing a connection.
I would recommend checking the settings on your pc to make sure your ethernet is configured properly. Perhaps this has been inadvertently changed. Also you could have a bad controller.
