DHC2. Initializes then the usb mouse stops
pipeliner
Post by pipeliner »
13 years & never a hiccup with my DHC2, yesterday the mouse quit working after initialize getting ready to cut, after several attempts I figured the pc was on the blink. Today hooked up another pc & it’s doing the same thing.
After the mouse quits, I shut off the table, unplug then plug in the usb mouse wire & the mouse works fine.
Any information or direction would be greatly appreciated !!!
Re: DHC2. Initializes then the usb mouse stops
In the scenario you describe where the mouse quits working, you switch computers, and the mouse still doesn't work - the first thing I would do is to replace the mouse with another one. You don't need to shut off your table in order to unplug/plug in the usb mouse. Since I use wireless usb mice, the first thing I check is the battery in the mouse when this sort of thing happens.
Joe Jones
Post by Joe Jones »
Get a LOGITECH mouse for DesignEdge. Did you recently update the software? Many years ago, DesignEdge used to have a compatibility problem with certain mouse brands. The solution was to go with the LOGITECH mouse, which does not use the same internal resources as DesignEdge uses for other purposes.
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
12 Lasers
FREE DesignEdge Training!
I use Logitech usb wireless keyboards and mice on all of my Plasmsacam control computers. But for general office use, I still like the feel of my Gateway corded keyboard for word processing and design use. But I do use the Logitech usb wireless mice on all three of my office computers as well - Windows 10,Windows 7, and Windows 2000 (for running the old AutoCad and MasterCam).
pipeliner
Post by pipeliner »
Thanks & I’ll try all mentioned today.
When I configured the Dell pc which I always have used HP to the machine it showed low voltage I forgot to add.
Will let you all know what happens 👍
pipeliner wrote: Thu Jul 21, 2022 5:24 am Thanks & I’ll try all mentioned today.
Was the low voltage message from the Plasmacam software or? What brand and model parallel card do you have installed?
pipeliner
Post by pipeliner »
Thanks for the help my friends !!!
The mouse was bad
The Dell I tried, the parallel port is not up to snuff
Back up & running 👍
Thanks again adbuch & Joe Jones
pipeliner wrote: Sat Jul 23, 2022 7:49 pm Thanks for the help my friends !!!
The mouse was bad
Back up & running 👍
:Like :Like :Like
