Hi. We're having a problem on connecting the Hypertherm 105A to torch height controller HYD XPTHC-100III.
In Hypertherm 105A we set the ratio to 50:1, while our thc have a fixed voltage divider ratio of 100:1.
What can we do about this?
Hypertherm 105A and THC Voltage Divider Ratio Issues
Re: Hypertherm 105A and THC Voltage Divider Ratio Issues
Hi Crich, Please contact our Technical Support team here at Hypertherm for help getting your Powermax 105 to your THC. you can reach them here:
(800) 643-9878 or https://www.hypertherm.com/en-US/contac ... -questions
Randy,
Marketing Data Specialist – Americas Region
Hypertherm Inc.
Hypertherm Inc.
Crich - If your 105A does not have the option to set the ratio to 100:1, then you can simply add a 2:1 divider to step down your divided arc voltage to the correct compatible level to match your thc.
