Are all Hypertherm 85 good for CNC?
mikeysp
Post by mikeysp »
Hi, I have a Hypertherm 85 and am hoping to make a CNC table soon, and I did not know if they were all fitted out for CNC machine usage?
If not, how do I find out if mine is? If not, can I upgrade it easily to work properly?
Thank you.
-Mike
robertspark
Re: Are all Hypertherm 85 good for CNC?
Post by robertspark »
they all can be
does it have a CPC on the rear (14 pin circular plastic connector)?
that is your CNC interface to fire the torch. get a transfer signal and a divided voltage output.
mikeysp
Post by mikeysp »
There is a 14 pin hole, but only 7 of the holes have an electrical contact (see attached pic)
cutnweld
Post by cutnweld »
You can buy the CPC kit from any hypertherm dealer and install it yourself, that's what I did. Comes with instructions, very easy to do.
5X10 Shop built table
20x80x32 inch gap lathe
10x40 lathe
10x54 milling machine
2-Miller 255
Miller XMT350MPA
Lincoln squarewave tig 255
12 Ft Durma Brake
mikeysp
Post by mikeysp »
I am little confused, can some clarify. Does my hypertherm have the CPC already? (pic above) Or do I need it + a 14 pin connector shown in pic?
Thank you.
-Mike
djreiswig
Post by djreiswig »
That's the CPC. Not all of the pins are used.
mikeysp
Post by mikeysp »
Great, it is an exact match to the connector in pic (my machine).
Thank you for clarification.
mikeysp wrote: Sat Jun 25, 2022 3:16 pm Hi, I have a Hypertherm 85 and am hoping to make a CNC table soon, and I did not know if they were all fitted out for CNC machine usage?
Thank you.
-Mike
Some have the CPC port, and some do not. For those without the CPC port when new, Hypertherm offers a CPC upgrade kit. My Hypertherm Powermax 85 did not come with CPC port, and it is not necessary for cnc applications using the hand torch. Since I am using the Duramax hand torch, I do not need the CPC port and instead my torch control cable is hardwired inside the plasma cutter. But for machine torch applications, the CPC port is necessary (for plug & play applications).
