Hi,
since two days I have a problem that after piercing the torch goes way up and does not really cut.
I change the nozzle to fine cut nozzel and I´m not really sure that I canged unexpected something at the settings.
No I want to bring down the cutting height to a normal position (around 20mm at the moment) but more or less I don´t really now how.
I do have a starfire controller and I contact the company tech support but the don´t answere me.
Would be great!!!
Thanks Rainer
adjusting cut hight at starfire controller SF 2100 BG
Re: adjusting cut hight at starfire controller SF 2100 BG
Rainer,RainerW wrote: ↑Tue Mar 29, 2022 3:22 pm Hi,
Would be great!!!
Thanks Rainer
Can you provide us with a pdf copy of your user manual for the controller.
Hi,
this is all I have!
I will make some more pictures of my controller
this is all I have!
I am have a similar problem with the Starfire. I think I have the correct height setting but it still flames out after piercing. Have changed all consumables.
Does it flame out because the torch is lifting too far from the material or is the height correct and it's just flaming out?Megabite787 wrote: ↑Thu Feb 15, 2024 7:17 pm I am have a similar problem with the Starfire. I think I have the correct height setting but it still flames out after piercing. Have changed all consumables.
The height was correct but now it’s going really high and I can’t get it back to cutting height.
Turn your auto torch height control off, that could be what is causing it to climb. Confirm you can cut shapes with success without the auto height control before you introduce that into the mix. Are you able to cut really well with the height control off?Megabite787 wrote: ↑Sat Feb 17, 2024 5:42 pm The height was correct but now it’s going really high and I can’t get it back to cutting height.
