Looking for aftermarket Coupling for Screw to Motor for my lifter
tulsajosh
Post by tulsajosh »
Looking for a after market or Original MFG part number/purchase to the Torchmate Gen 1-Gen 2 Smart motor lifter statation ball screw coupling. Im sure it's on McMasters site but not sure which one im looking for
Re: Looking for aftermarket Coupling for Screw to Motor for my lifter
Does it look like any of these?
https://www.mcmaster.com/ball-screw-actuators/
tulsajosh
Post by tulsajosh »
no, it looks like this but way over prices from lincoln https://www.torchmatestore.com/Screw-Co ... _3195.html
weldguy
Post by weldguy »
If that's all you need I suspect if the ID is correct for your shafts and the OD is not too large you could use almost any shaft coupling.
tulsajosh wrote: Thu Mar 24, 2022 11:57 am no, it looks like this but way over prices from lincoln https://www.torchmatestore.com/Screw-Co ... _3195.html
What size is your shaft that fits into the coupling? Shaft outside diameter? I have several sources for these at very inexpensive prices.
tulsajosh
Post by tulsajosh »
I think i got it solved, Just ordered one with smaller diameter and drilled out to the size needed but there was 2 different odd ball sizes and seems to be working just fine now. Thank you everyone
weldguy
Post by weldguy »
:Like :Like
Return to “Torchmate Forum”
