Hello all,
I just got my easy scriber and I am running a maverick MV510 but I cannot get it to run. I keep getting the error code m100/101.
I believe this is because the marking fab head option in this software is for their pneumatic scriber that runs off of the air supply for the plasma power source.
any advice would be appreciated.
-cody
Maverick CNC with easy scriber not working
Re: Maverick CNC with easy scriber not working
If you can run G-codes generated by SheetCam just use a generic post processor using a router protocol with a shallow cut depth. I use that for drag knife cutting, metal scribe, Plotter pen and engraving operations. Just don't exceed the easy scribe spring preload.
I'm with AC, a different post processor is likely all you need. Just try the post you use for plasma cutting and let us know what happens.
