My Crossfire pros new home !!!
My new home for my Crossfire pro. Getting ready to fire it up ....
Re: My Crossfire pros new home !!!
Nice clean setup! Did your machine include a water tray? If not, then consider adding some sort of exhaust system to vent all the plasma dust/smoke from the interior of your building.
very interesting looks like the table corral is portable, neat idea.
Hey is that a really portable cylinder?? or a fancy door stop
Clean crisp setup, I love it! Good eye AC, curious about that myself....
Or is it the top of a buried gas cylinder?
Thanks for the explanation! Those water trays are a great way to go and can eliminate much of the smoke and dust when properly set up. I use a similar combination of water tray plus draft system on my Plasmacam table.All Cut Up wrote: ↑Fri Dec 31, 2021 9:43 pm Yes it did come with water tray its on it Just doesnt have water in it when not in use.. The exhaust fan is above to the right of picture . In the wall it has a door on it . So when its not in use . I can close it so winter weather doesnt get in. It has lovers for the fan but they are not air tight. And leak cold air when not in use so . I built a air tight door for the exhaust fan..
https://photos.app.goo.gl/h8LHufi6frttfGNQA
Strange how you quoted his reply, but I don't see it in the thread.adbuch wrote: ↑Sat Jan 01, 2022 6:06 pmThanks for the explanation! Those water trays are a great way to go and can eliminate much of the smoke and dust when properly set up. I use a similar combination of water tray plus draft system on my Plasmacam table.All Cut Up wrote: ↑Fri Dec 31, 2021 9:43 pm Yes it did come with water tray its on it Just doesnt have water in it when not in use.. The exhaust fan is above to the right of picture . In the wall it has a door on it . So when its not in use . I can close it so winter weather doesnt get in. It has lovers for the fan but they are not air tight. And leak cold air when not in use so . I built a air tight door for the exhaust fan..
I know what you mean - it is sort of a mystery.
