Here is a tool that may help with metal surface conditioning, remove mill scale and surface rust. Attached are images of a 2" square tube I tried the tool on and was pleased with the result. I have other wheels on order from Eastwood, (60 and 80 Grit interleaf drums).
The tool is from Amazon at $100 with 2 wheels, it has a variable speed knob. It seems to a adaption of a polishing type tool. It remove the mill scale and surface rust on the tube in about 30 second with little effort. The drums from Eastwood have a plastic center and fit on the tool very easily. I did need to file the 2 keyway slots on the tool a small amount for the keys to slide in. They have other drums that they have on sale intermittently like the last one shown one
the tool
80 grit drum from Eastwood https://www.eastwood.com/eastwood-conto ... -grit.html
60 grit from Eastwood https://www.eastwood.com/eastwood-conto ... -grit.html
https://www.eastwood.com/eastwood-conto ... -drum.html
Metal surface conditioning tool
Re: surface conditioning tool
Tom - thanks for showing us that neat tool! I will definitely check it out.
I have used one before for putting a brushed finish on aluminum tube they work awesome. Great tool for sure
- tnbndr
I have a similar but different brand tool. Use it for different grind finishes. Especially does a nice straight grind for a clean look.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
Based on these reviews, I think I will order one to try it out. I like the fact that it will put a "brushed" type finish with straight lines as opposed to the normal grind marks I get with my #80 flap disk. Some of the reviews on Amazon said it was pretty loud compared to a regular grinder, but I guess I will find out.
You will really like it David, I don't use it often but when I do I sure appreciate it. Awesome for stainless and aluminum finishing especially.
Thanks! I ordered it last night along with this. The belt sander is not necessarily for plasma parts, but I have wanted one for a long time and decided to pull the trigger. One of the things I love about Amazon is that it is so easy to return an item if I don't like it. This belt sander had great reviews, and I think will work well for some of the "hot rod" stuff I do from time to time.
https://www.amazon.com/gp/product/B00L5 ... UTF8&psc=1
I bought the Eastwood CONTOUR SCT - Surface Conditioning Tool// and it works very well.. Variable speed.and most important. Gear Reduction ! There is alot of different drums you can buy for this item. But as far as shine.. yes, Here is a 4 foot item that was hot roll. and it cleaned it up really good.
4x10 Home Built Super Table.
4x4x6` Home Built LP Powder Coat oven
Hypertherm 45 xp plasma cutter
Eastwood 60 amp Plasma Cutter
Eastwood Powder Coating Gun
Miller 252 Mig with Spool Gun
Lincoln 100 Mig
Build Trailers
Lincoln 100 Mig
Build Trailers
Thanks! That explains why some of the Amazon reviews talked about how loud is it. I've got several of the Hougen Mag Drills with gear reduction and they too are pretty loud compared to a regular drill. In fact - I wear ear plugs when I use them.Dishtech55 wrote: ↑Thu Oct 28, 2021 12:00 pm I bought the Eastwood CONTOUR SCT - Surface Conditioning Tool// and it works very well.. Variable speed.and most important. Gear Reduction !
LOL .. Well good deal... As long as they work as we need them too.. thats what counts..adbuch wrote: ↑Thu Oct 28, 2021 8:29 pmThanks! That explains why some of the Amazon reviews talked about how loud is it. I've got several of the Hougen Mag Drills with gear reduction and they too are pretty loud compared to a regular drill. In fact - I wear ear plugs when I use them.Dishtech55 wrote: ↑Thu Oct 28, 2021 12:00 pm I bought the Eastwood CONTOUR SCT - Surface Conditioning Tool// and it works very well.. Variable speed.and most important. Gear Reduction !
Lincoln 100 Mig
Build Trailers
Lincoln 100 Mig
Build Trailers
a couple companys also carry "the restorer" that is the same concept for cheap. i follow the inventor on instagram and hes a very stand up guy that stands by his product and will also post very good deals from your local lowes/home depot
