MyPlasm CNC File Load Error
Hi Everyone, we use Autodesk Fusion 360 to design. We save sketches as dxf files. Sometimes this works however sometimes when we load into MyPlasm CNC we get a FILE LOAD ERROR and the image will not upload. Any ideas on what we are doing wrong saving in Autodesk or uploading to MyPlasm? Thanks in advance!
- East German
Re: MyPlasm CNC File Load Error
Try another export version or upload the DXF here then you can have a look at it !!?
Peter
Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
Save as an older version DXF, like 2004 If you can't save back that far, someone on here will do it for you. The software you are drawing with is simply a newer version than the one trying to read it....it has attributes that the older software has no clue what to do with so it boots it out.... Ya dun fried it's brain!!!! Ya just gotta dumb it down a bit....
