Mach 3 raising instead of touching
After first cut it goes to next hole and instead of touching material to get 0 it raises 1/2” and cuts then does the same on the next holes till get goes to a new part.
Re: Mach 3 raising instead of touching
A little info on your system might help, table manufacture, operational software, screenshot of the part of the G-code that fails.
Aas table 6’x12’ Mach 3 soft ware with sheet cam. But this is intermittent ran once cut first like listed then cleared it out 2-3 times then cut out first part as it should and second then messed up the 3rd.
sounds like you are missing a touchoff sequence but are asking it to return to safe z height.....Leeroy6392 wrote: ↑Fri Mar 12, 2021 3:49 pm After first cut it goes to next hole and instead of touching material to get 0 it raises 1/2” and cuts then does the same on the next holes till get goes to a new part.
did you buy a mach3 licence or given it... as the fake licences have gremlins to mess up your cut.... to be fair it serves those that can't be bothered to buy a licence right!
but give us a clue.... post some screenshots.... gcode anything.... crystal ball is presently on loan to someone else
N0010 (Filename: trailer.tap)
N0020 (Post processor: Mach3 flame with THC - G31.scpost)
N0030 (Date: 14/03/2021)
N0040 G20 (Units: Inches)
N0050 G53 G90 G40
N0060 F1
N0070 S500
N0080 (Part: beam clips Duplicate 4)
N0090 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N0100 M06 T2 (Plasma, 0.09 in kerf)
N0110 G00 X23.1594 Y1.1917 Z0.5000
N0120 G31 Z -100 F19.685
N0130 G92 Z-0.0800
N0140 G00 Z0.1500
N0150 M03
N0160 G04 P0.7
N0170 G01 X23.1594 Y1.1917 Z0.0500 F45
N0180 G03 X23.2874 Y1.0637 I0.1280 J0.0000 F45.0
N0190 X23.2874 Y1.0637 I0.0000 J0.3300
N0200 (Part: beam clips Duplicate 3)
N0210 X23.4154 Y1.1917 I0.0000 J0.1280
N0220 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N0230 M05
N0240 G04 P0.2
N0250 G00 Z0.5000
N0260 X28.2775
N0270 G31 Z -100 F19.685
N0280 G92 Z-0.0800
N0290 G00 Z0.1500
N0300 M03
N0310 G04 P0.7
N0320 G01 X28.2775 Y1.1917 Z0.0500 F45
N0330 G03 X28.4055 Y1.0637 I0.1280 J0.0000 F45.0
N0340 X28.4055 Y1.0637 I0.0000 J0.3300
N0350 (Part: beam clips Duplicate 2)
N0360 X28.5335 Y1.1917 I0.0000 J0.1280
N0370 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N0380 M05
N0390 G04 P0.2
N0400 G00 Z0.5000
N0410 X33.3956
N0420 G31 Z -100 F19.685
N0430 G92 Z-0.0800
N0440 G00 Z0.1500
N0450 M03
N0460 G04 P0.7
N0470 G01 X33.3956 Y1.1917 Z0.0500 F45
N0480 G03 X33.5236 Y1.0637 I0.1280 J0.0000 F45.0
N0490 X33.5236 Y1.0637 I0.0000 J0.3300
N0500 (Part: beam clips Duplicate 1)
N0510 X33.6516 Y1.1917 I0.0000 J0.1280
N0520 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N0530 M05
N0540 G04 P0.2
N0550 G00 Z0.5000
N0560 X38.5137
N0570 G31 Z -100 F19.685
N0580 G92 Z-0.0800
N0590 G00 Z0.1500
N0600 M03
N0610 G04 P0.7
N0620 G01 X38.5137 Y1.1917 Z0.0500 F45
N0630 G03 X38.6417 Y1.0637 I0.1280 J0.0000 F45.0
N0640 X38.6417 Y1.0637 I0.0000 J0.3300
N0650 (Part: beam clips)
N0660 X38.7697 Y1.1917 I0.0000 J0.1280
N0670 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N0680 M05
N0690 G04 P0.2
N0700 G00 Z0.5000
N0710 X43.6318
N0720 G31 Z -100 F19.685
N0730 G92 Z-0.0800
N0740 G00 Z0.1500
N0750 M03
N0760 G04 P0.7
N0770 G01 X43.6318 Y1.1917 Z0.0500 F45
N0780 G03 X43.7598 Y1.0637 I0.1280 J0.0000 F45.0
N0790 X43.7598 Y1.0637 I0.0000 J0.3300
N0800 (Part: beam clips Duplicate 5)
N0810 X43.8878 Y1.1917 I0.0000 J0.1280
N0820 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N0830 M05
N0840 G04 P0.2
N0850 G00 Z0.5000
N0860 X43.6318 Y11.4279
N0870 G31 Z -100 F19.685
N0880 G92 Z-0.0800
N0890 G00 Z0.1500
N0900 M03
N0910 G04 P0.7
N0920 G01 X43.6318 Y11.4279 Z0.0500 F45
N0930 G03 X43.7598 Y11.2999 I0.1280 J0.0000 F45.0
N0940 X43.7598 Y11.2999 I0.0000 J0.3300
N0950 (Part: beam clips Duplicate 6)
N0960 X43.8878 Y11.4279 I0.0000 J0.1280
N0970 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N0980 M05
N0990 G04 P0.2
N1000 G00 Z0.5000
N1010 X38.5137
N1020 G31 Z -100 F19.685
N1030 G92 Z-0.0800
N1040 G00 Z0.1500
N1050 M03
N1060 G04 P0.7
N1070 G01 X38.5137 Y11.4279 Z0.0500 F45
N1080 G03 X38.6417 Y11.2999 I0.1280 J0.0000 F45.0
N1090 X38.6417 Y11.2999 I0.0000 J0.3300
N1100 (Part: beam clips Duplicate 7)
N1110 X38.7697 Y11.4279 I0.0000 J0.1280
N1120 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N1130 M05
N1140 G04 P0.2
N1150 G00 Z0.5000
N1160 X33.3956
N1170 G31 Z -100 F19.685
N1180 G92 Z-0.0800
N1190 G00 Z0.1500
N1200 M03
N1210 G04 P0.7
N1220 G01 X33.3956 Y11.4279 Z0.0500 F45
N1230 G03 X33.5236 Y11.2999 I0.1280 J0.0000 F45.0
N1240 X33.5236 Y11.2999 I0.0000 J0.3300
N1250 (Part: beam clips Duplicate 8)
N1260 X33.6516 Y11.4279 I0.0000 J0.1280
N1270 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N1280 M05
N1290 G04 P0.2
N1300 G00 Z0.5000
N1310 X28.2775
N1320 G31 Z -100 F19.685
N1330 G92 Z-0.0800
N1340 G00 Z0.1500
N1350 M03
N1360 G04 P0.7
N1370 G01 X28.2775 Y11.4279 Z0.0500 F45
N1380 G03 X28.4055 Y11.2999 I0.1280 J0.0000 F45.0
N1390 X28.4055 Y11.2999 I0.0000 J0.3300
N1400 (Part: beam clips Duplicate 9)
N1410 X28.5335 Y11.4279 I0.0000 J0.1280
N1420 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N1430 M05
N1440 G04 P0.2
N1450 G00 Z0.5000
N1460 X23.1594
N1470 G31 Z -100 F19.685
N1480 G92 Z-0.0800
N1490 G00 Z0.1500
N1500 M03
N1510 G04 P0.7
N1520 G01 X23.1594 Y11.4279 Z0.0500 F45
N1530 G03 X23.2874 Y11.2999 I0.1280 J0.0000 F45.0
N1540 X23.2874 Y11.2999 I0.0000 J0.3300
N1550 (Part: beam clips Duplicate 14)
N1560 X23.4154 Y11.4279 I0.0000 J0.1280
N1570 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N1580 M05
N1590 G04 P0.2
N1600 G00 Z0.5000
N1610 X23.1594 Y21.6641
N1620 G31 Z -100 F19.685
N1630 G92 Z-0.0800
N1640 G00 Z0.1500
N1650 M03
N1660 G04 P0.7
N1670 G01 X23.1594 Y21.6641 Z0.0500 F45
N1680 G03 X23.2874 Y21.5361 I0.1280 J0.0000 F45.0
N1690 X23.2874 Y21.5361 I0.0000 J0.3300
N1700 (Part: beam clips Duplicate 13)
N1710 X23.4154 Y21.6641 I0.0000 J0.1280
N1720 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N1730 M05
N1740 G04 P0.2
N1750 G00 Z0.5000
N1760 X28.2775
N1770 G31 Z -100 F19.685
N1780 G92 Z-0.0800
N1790 G00 Z0.1500
N1800 M03
N1810 G04 P0.7
N1820 G01 X28.2775 Y21.6641 Z0.0500 F45
N1830 G03 X28.4055 Y21.5361 I0.1280 J0.0000 F45.0
N1840 X28.4055 Y21.5361 I0.0000 J0.3300
N1850 (Part: beam clips Duplicate 12)
N1860 X28.5335 Y21.6641 I0.0000 J0.1280
N1870 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N1880 M05
N1890 G04 P0.2
N1900 G00 Z0.5000
N1910 X33.3956
N1920 G31 Z -100 F19.685
N1930 G92 Z-0.0800
N1940 G00 Z0.1500
N1950 M03
N1960 G04 P0.7
N1970 G01 X33.3956 Y21.6641 Z0.0500 F45
N1980 G03 X33.5236 Y21.5361 I0.1280 J0.0000 F45.0
N1990 X33.5236 Y21.5361 I0.0000 J0.3300
N2000 (Part: beam clips Duplicate 11)
N2010 X33.6516 Y21.6641 I0.0000 J0.1280
N2020 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N2030 M05
N2040 G04 P0.2
N2050 G00 Z0.5000
N2060 X38.5137
N2070 G31 Z -100 F19.685
N2080 G92 Z-0.0800
N2090 G00 Z0.1500
N2100 M03
N2110 G04 P0.7
N2120 G01 X38.5137 Y21.6641 Z0.0500 F45
N2130 G03 X38.6417 Y21.5361 I0.1280 J0.0000 F45.0
N2140 X38.6417 Y21.5361 I0.0000 J0.3300
N2150 (Part: beam clips Duplicate 10)
N2160 X38.7697 Y21.6641 I0.0000 J0.1280
N2170 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N2180 M05
N2190 G04 P0.2
N2200 G00 Z0.5000
N2210 X43.6318
N2220 G31 Z -100 F19.685
N2230 G92 Z-0.0800
N2240 G00 Z0.1500
N2250 M03
N2260 G04 P0.7
N2270 G01 X43.6318 Y21.6641 Z0.0500 F45
N2280 G03 X43.7598 Y21.5361 I0.1280 J0.0000 F45.0
N2290 X43.7598 Y21.5361 I0.0000 J0.3300
N2300 (Part: truck clip Duplicate 1)
N2310 X43.8878 Y21.6641 I0.0000 J0.1280
N2320 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N2330 M05
N2340 G04 P0.2
N2350 G00 Z0.5000
N2360 X45.6726 Y31.8830
N2370 G31 Z -100 F19.685
N2380 G92 Z-0.0800
N2390 G00 Z0.1500
N2400 M03
N2410 G04 P0.7
N2420 G01 X45.6726 Y31.8830 Z0.0500 F45
N2430 G02 X45.6033 Y31.7158 I-0.1183 J-0.0490 F50.0
N2440 X45.6033 Y31.7158 I0.0000 J0.1425
N2450 X45.5341 Y31.8830 I0.0490 J0.1183
N2460 (Process: Outside Offset, 1, T2: Plasma, 0.09 in kerf)
N2470 M05
N2480 G04 P0.2
N2490 G00 Z0.5000
N2500 X46.4013 Y31.1053
N2510 Z0.1500
N2520 M03
N2530 G04 P0.7
N2540 G01 Z0.0500 F45
N2550 G02 X46.2733 Y31.2333 I0.0000 J0.1280 F65.0
N2560 G01 Y31.8583 F65
N2570 G03 X44.9333 Y31.8583 I-0.6700 J0.0000 F65.0
N2580 G01 Y31.2333 F65
N2590 G03 X44.9783 Y31.1883 I0.0450 J0.0000 F65.0
N2600 G01 X46.2283 F65
N2610 (Part: truck clip)
N2620 G02 X46.3563 Y31.0603 I0.0000 J-0.1280 F65.0
N2630 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N2640 M05
N2650 G04 P0.2
N2660 G00 Z0.5000
N2670 X47.2474 Y31.8830
N2680 G31 Z -100 F19.685
N2690 G92 Z-0.0800
N2700 G00 Z0.1500
N2710 M03
N2720 G04 P0.7
N2730 G01 X47.2474 Y31.8830 Z0.0500 F45
N2740 G02 X47.1781 Y31.7158 I-0.1183 J-0.0490 F50.0
N2750 X47.1781 Y31.7158 I0.0000 J0.1425
N2760 X47.1089 Y31.8830 I0.0490 J0.1183
N2770 (Process: Outside Offset, 1, T2: Plasma, 0.09 in kerf)
N2780 M05
N2790 G04 P0.2
N2800 G00 Z0.5000
N2810 X47.9761 Y31.1053
N2820 Z0.1500
N2830 M03
N2840 G04 P0.7
N2850 G01 Z0.0500 F45
N2860 G02 X47.8481 Y31.2333 I0.0000 J0.1280 F65.0
N2870 G01 Y31.8583 F65
N2880 G03 X46.5081 Y31.8583 I-0.6700 J0.0000 F65.0
N2890 G01 Y31.2333 F65
N2900 G03 X46.5531 Y31.1883 I0.0450 J0.0000 F65.0
N2910 G01 X47.8031 F65
N2920 (Part: truck clip Duplicate 2)
N2930 G02 X47.9311 Y31.0603 I0.0000 J-0.1280 F65.0
N2940 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N2950 M05
N2960 G04 P0.2
N2970 G00 Z0.5000
N2980 X47.2474 Y33.4578
N2990 G31 Z -100 F19.685
N3000 G92 Z-0.0800
N3010 G00 Z0.1500
N3020 M03
N3030 G04 P0.7
N3040 G01 X47.2474 Y33.4578 Z0.0500 F45
N3050 G02 X47.1781 Y33.2906 I-0.1183 J-0.0490 F50.0
N3060 X47.1781 Y33.2906 I0.0000 J0.1425
N3070 X47.1089 Y33.4578 I0.0490 J0.1183
N3080 (Process: Outside Offset, 1, T2: Plasma, 0.09 in kerf)
N3090 M05
N3100 G04 P0.2
N3110 G00 Z0.5000
N3120 X47.9761 Y32.6801
N3130 Z0.1500
N3140 M03
N3150 G04 P0.7
N3160 G01 Z0.0500 F45
N3170 G02 X47.8481 Y32.8081 I0.0000 J0.1280 F65.0
N3180 G01 Y33.4331 F65
N3190 G03 X46.5081 Y33.4331 I-0.6700 J0.0000 F65.0
N3200 G01 Y32.8081 F65
N3210 G03 X46.5531 Y32.7631 I0.0450 J0.0000 F65.0
N3220 G01 X47.8031 F65
N3230 (Part: truck clip Duplicate 3)
N3240 G02 X47.9311 Y32.6351 I0.0000 J-0.1280 F65.0
N3250 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N3260 M05
N3270 G04 P0.2
N3280 G00 Z0.5000
N3290 X45.6726 Y33.4578
N3300 G31 Z -100 F19.685
N3310 G92 Z-0.0800
N3320 G00 Z0.1500
N3330 M03
N3340 G04 P0.7
N3350 G01 X45.6726 Y33.4578 Z0.0500 F45
N3360 G02 X45.6033 Y33.2906 I-0.1183 J-0.0490 F50.0
N3370 X45.6033 Y33.2906 I0.0000 J0.1425
N3380 X45.5341 Y33.4578 I0.0490 J0.1183
N3390 (Process: Outside Offset, 1, T2: Plasma, 0.09 in kerf)
N3400 M05
N3410 G04 P0.2
N3420 G00 Z0.5000
N3430 X46.4013 Y32.6801
N3440 Z0.1500
N3450 M03
N3460 G04 P0.7
N3470 G01 Z0.0500 F45
N3480 G02 X46.2733 Y32.8081 I0.0000 J0.1280 F65.0
N3490 G01 Y33.4331 F65
N3500 G03 X44.9333 Y33.4331 I-0.6700 J0.0000 F65.0
N3510 G01 Y32.8081 F65
N3520 G03 X44.9783 Y32.7631 I0.0450 J0.0000 F65.0
N3530 G01 X46.2283 F65
N3540 (Part: truck clip Duplicate 5)
N3550 G02 X46.3563 Y32.6351 I0.0000 J-0.1280 F65.0
N3560 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N3570 M05
N3580 G04 P0.2
N3590 G00 Z0.5000
N3600 X44.0978 Y33.4578
N3610 G31 Z -100 F19.685
N3620 G92 Z-0.0800
N3630 G00 Z0.1500
N3640 M03
N3650 G04 P0.7
N3660 G01 X44.0978 Y33.4578 Z0.0500 F45
N3670 G02 X44.0285 Y33.2906 I-0.1183 J-0.0490 F50.0
N3680 X44.0285 Y33.2906 I0.0000 J0.1425
N3690 X43.9593 Y33.4578 I0.0490 J0.1183
N3700 (Process: Outside Offset, 1, T2: Plasma, 0.09 in kerf)
N3710 M05
N3720 G04 P0.2
N3730 G00 Z0.5000
N3740 X44.8265 Y32.6801
N3750 Z0.1500
N3760 M03
N3770 G04 P0.7
N3780 G01 Z0.0500 F45
N3790 G02 X44.6985 Y32.8081 I0.0000 J0.1280 F65.0
N3800 G01 Y33.4331 F65
N3810 G03 X43.3585 Y33.4331 I-0.6700 J0.0000 F65.0
N3820 G01 Y32.8081 F65
N3830 G03 X43.4035 Y32.7631 I0.0450 J0.0000 F65.0
N3840 G01 X44.6535 F65
N3850 (Part: truck clip Duplicate 4)
N3860 G02 X44.7815 Y32.6351 I0.0000 J-0.1280 F65.0
N3870 (Process: Inside Offset, 0, T2: Plasma, 0.09 in kerf)
N3880 M05
N3890 G04 P0.2
N3900 G00 Z0.5000
N3910 X44.0978 Y31.8830
N3920 G31 Z -100 F19.685
N3930 G92 Z-0.0800
N3940 G00 Z0.1500
N3950 M03
N3960 G04 P0.7
N3970 G01 X44.0978 Y31.8830 Z0.0500 F45
N3980 G02 X44.0285 Y31.7158 I-0.1183 J-0.0490 F50.0
N3990 X44.0285 Y31.7158 I0.0000 J0.1425
N4000 X43.9593 Y31.8830 I0.0490 J0.1183
N4010 (Process: Outside Offset, 1, T2: Plasma, 0.09 in kerf)
N4020 M05
N4030 G04 P0.2
N4040 G00 Z0.5000
N4050 X44.8265 Y31.1053
N4060 Z0.1500
N4070 M03
N4080 G04 P0.7
N4090 G01 Z0.0500 F45
N4100 G02 X44.6985 Y31.2333 I0.0000 J0.1280 F65.0
N4110 G01 Y31.8583 F65
N4120 G03 X43.3585 Y31.8583 I-0.6700 J0.0000 F65.0
N4130 G01 Y31.2333 F65
N4140 G03 X43.4035 Y31.1883 I0.0450 J0.0000 F65.0
N4150 G01 X44.6535 F65
N4160 G02 X44.7815 Y31.0603 I0.0000 J-0.1280 F65.0
N4170 M05
N4180 G04 P0.2
N4190 G00 Z0.5000
N4200 M05 M30
this was a new purchase table from the manufacturer. After more looking into it and trying to get any help from them i could definitely see it being a false copy not to mention the computer is telling me know this may be a counterfeit windows!!! i chalked it up to being a refurb tower with cheap software. but after reading more on here i am ready to but new tower and get mach 4 to hopefully not have these issues. but it is a roll of the dice on the day if it will work properly and for how long.
N0050 G53 G90 G40
N0060 F1
N0070 S500
N0130 G92 Z-0.0800
N0140 G00 Z0.1500
N0150 M03
N0160 G04 P0.7
N0230 M05
N0240 G04 P0.2
N0250 G00 Z0.5000
N0260 X28.2775
N0280 G92 Z-0.0800
N0290 G00 Z0.1500
N0300 M03
N0310 G04 P0.7
N0380 M05
N0390 G04 P0.2
N0400 G00 Z0.5000
N0410 X33.3956
N0430 G92 Z-0.0800
N0440 G00 Z0.1500
N0450 M03
N0460 G04 P0.7
N0530 M05
N0540 G04 P0.2
N0550 G00 Z0.5000
N0560 X38.5137
N0580 G92 Z-0.0800
N0590 G00 Z0.1500
N0600 M03
N0610 G04 P0.7
N0680 M05
N0690 G04 P0.2
N0700 G00 Z0.5000
N0710 X43.6318
N0730 G92 Z-0.0800
N0740 G00 Z0.1500
N0750 M03
N0760 G04 P0.7
N0830 M05
N0840 G04 P0.2
N0850 G00 Z0.5000
N0880 G92 Z-0.0800
N0890 G00 Z0.1500
N0900 M03
N0910 G04 P0.7
N0980 M05
N0990 G04 P0.2
N1000 G00 Z0.5000
N1010 X38.5137
N1030 G92 Z-0.0800
N1040 G00 Z0.1500
N1050 M03
N1060 G04 P0.7
N1130 M05
N1140 G04 P0.2
N1150 G00 Z0.5000
N1160 X33.3956
N1180 G92 Z-0.0800
N1190 G00 Z0.1500
N1200 M03
N1210 G04 P0.7
N1280 M05
N1290 G04 P0.2
N1300 G00 Z0.5000
N1310 X28.2775
N1330 G92 Z-0.0800
N1340 G00 Z0.1500
N1350 M03
N1360 G04 P0.7
N1430 M05
N1440 G04 P0.2
N1450 G00 Z0.5000
N1460 X23.1594
N1480 G92 Z-0.0800
N1490 G00 Z0.1500
N1500 M03
N1510 G04 P0.7
N1580 M05
N1590 G04 P0.2
N1600 G00 Z0.5000
N1630 G92 Z-0.0800
N1640 G00 Z0.1500
N1650 M03
N1660 G04 P0.7
N1730 M05
N1740 G04 P0.2
N1750 G00 Z0.5000
N1760 X28.2775
N1780 G92 Z-0.0800
N1790 G00 Z0.1500
N1800 M03
N1810 G04 P0.7
N1880 M05
N1890 G04 P0.2
N1900 G00 Z0.5000
N1910 X33.3956
N1930 G92 Z-0.0800
N1940 G00 Z0.1500
N1950 M03
N1960 G04 P0.7
N2030 M05
N2040 G04 P0.2
N2050 G00 Z0.5000
N2060 X38.5137
N2080 G92 Z-0.0800
N2090 G00 Z0.1500
N2100 M03
N2110 G04 P0.7
N2180 M05
N2190 G04 P0.2
N2200 G00 Z0.5000
N2210 X43.6318
N2230 G92 Z-0.0800
N2240 G00 Z0.1500
N2250 M03
N2260 G04 P0.7
N2330 M05
N2340 G04 P0.2
N2350 G00 Z0.5000
N2380 G92 Z-0.0800
N2390 G00 Z0.1500
N2400 M03
N2410 G04 P0.7
N2470 M05
N2480 G04 P0.2
N2490 G00 Z0.5000
N2510 Z0.1500
N2520 M03
N2530 G04 P0.7
N2640 M05
N2650 G04 P0.2
N2660 G00 Z0.5000
N2690 G92 Z-0.0800
N2700 G00 Z0.1500
N2710 M03
N2720 G04 P0.7
N2780 M05
N2790 G04 P0.2
N2800 G00 Z0.5000
N2820 Z0.1500
N2830 M03
N2840 G04 P0.7
N2950 M05
N2960 G04 P0.2
N2970 G00 Z0.5000
N3000 G92 Z-0.0800
N3010 G00 Z0.1500
N3020 M03
N3030 G04 P0.7
N3090 M05
N3100 G04 P0.2
N3110 G00 Z0.5000
N3130 Z0.1500
N3140 M03
N3150 G04 P0.7
N3260 M05
N3270 G04 P0.2
N3280 G00 Z0.5000
N3310 G92 Z-0.0800
N3320 G00 Z0.1500
N3330 M03
N3340 G04 P0.7
N3400 M05
N3410 G04 P0.2
N3420 G00 Z0.5000
N3440 Z0.1500
N3450 M03
N3460 G04 P0.7
N3570 M05
N3580 G04 P0.2
N3590 G00 Z0.5000
N3620 G92 Z-0.0800
N3630 G00 Z0.1500
N3640 M03
N3650 G04 P0.7
N3710 M05
N3720 G04 P0.2
N3730 G00 Z0.5000
N3750 Z0.1500
N3760 M03
N3770 G04 P0.7
N3880 M05
N3890 G04 P0.2
N3900 G00 Z0.5000
N3930 G92 Z-0.0800
N3940 G00 Z0.1500
N3950 M03
N3960 G04 P0.7
N4020 M05
N4030 G04 P0.2
N4040 G00 Z0.5000
N4060 Z0.1500
N4070 M03
N4080 G04 P0.7
N4170 M05
N4180 G04 P0.2
N4190 G00 Z0.5000
N4200 M05 M30
the touchoff sequence is in there and repeated a number of times
consider other options than just buying mach3 as it is no longer developed and has not been updated in nearly 10 years and there are other better and much more cost effective options available at less than $175 including alternative hardware
Code: Select all
N0280 G92 Z-0.0800
N0290 G00 Z0.1500
What would you recommend? I have a spare laptop and thought about getting the Mach4 today. I have looked at flash cut but need to do a total over haul of my table and could honestly spend a little bit more and get one built and delivered. This is used as a portion of my income so I need it to work properly. I also want to add a dthc to it and upgrade my z axis/ torch holder. I Would also be interested in talking to one of you on the phone so I don’t have to wait for a reply just pm me if you are ok with that. Thanks for all the continued help though I would be comepletely lost if it wasn’t for this site!
I try not to recommend anything any more, because I fairly recently recommended something to someone that I use and their development has declined of late and been disappointing.
My journey has been:
Mach3
Mach4
UCCNC
LinuxCNC
I am presently changing to LinuxCNC as it does everything for me (mill, router, plasma and lathe) and is the most flexible (I am not 100% up and running yet, but that is because of my setup sharing drives between various machines from 1 PC). Its learning curve (in my opinion) is steep, but only if you wish to do something out of the ordinary that is....... but that applies to all software(s).
https://cncdrive.com/UCCNC.html
https://forum.linuxcnc.org/plasmac/3723 ... umentation
really you need to do your own research and make a choice.
I have spent a small fortune on hardware over the years, on my journey...... really I should have bitten the bullet years ago and learnt linux + linuxcnc back then and ignored the rest, but YMMV.
There are so many options available now for plasma and cnc controllers, all have positive and negative points, and I have slowly outgrown the standard box offerings over the years.
The problem with MAch3 and Mach4 is that you are dependant upon the developer of the hardware whether items are integrated / available as some functions only exist within the motion controller (such as jogging, probing and simple THC UP and THC DN and laser control (synchronous M-codes)
UCCNC is a bit more closed in that the hardware is backward compatible (largely, some functions are not backward available like THC for Mach4) with Mach3 and Mach4 and UCCNC software is developed specifically for the cncdrive motion controllers.
Linuxcnc appears limitless..... if you can programme..... or get your head into how to do stuff.... I am still learning.
Just do some research and reading. Afterall this is just one persons view and there are 100's , 1000's? or maybe 10,000+ people happy with Mach3, Mach4, UCCNC etc. hence my knowledge is very limited to my own experience and needs and requirements of setup.
Mach3
Mach4
UCCNC
LinuxCNC
