esab powercut 700
esab powercut 700
Has anyone found where the arc voltage would be on the 700, seeing if i can hook this esab up to my table. Also where the easiest place to grab the torch on/off wire?
Re: esab powercut 700
If it has a hand torch locate the hand torch trigger wires coming out of the hip into the plasma cutter. Opening up the hand torch to determine wire color of the trigger wires will be helpful.
Raw arc voltage can be accessed inside the plasma cutter. Where your ground lead attaches to the circuit board inside the machine is where you would connect your THC + lead. There is likley a gang of similar colored wires coming out of the torch lead into the plasma cutter that feed the electrode current, where these wires connect at the circuit board is where you connect your THC - lead.
Good luck.
Good luck.
