Inkscape to sheet cam letter issues (sometimes)
sho_me82
Post by sho_me82 »
It’s only sometimes when I edit a file it does this. Other times no issues have tried different font styles same thing. And yes I have went and cleaned up nodes by deleting them on the letters. If I open 1:1 it looks like pic below if I open 25:1 it looks fine? Don’t know of a way to scale in sheet cam tho. In Inkscape the image is 24w x 14h. I have shrunk image down to 6x3 and still same thing. I’m lost on what to do.
AREA
Re: Inkscape to sheet cam letter issues (sometimes)
Post by AREA »
So it only does this when you scale down real small?
When you import a drawing you can scale the drawing as shown in the image below. Now if you draw in inches and save in DXF you click on the inch box. If you save the drawing in SVG you scale it 1:1. What I see in your image is the small red box in the lower left and the screen if black. This is showing you have not selected the correct size of you material or work field. This is done in the setup of SheetCam see the attached images.
scaling 2.JPG (72.93 KiB) Viewed 1221 times
scaling 3.JPG (46.8 KiB) Viewed 1221 times
scaling 4.JPG (41.61 KiB) Viewed 1221 times
sho_me82
Post by sho_me82 »
Yes i save as svg in inches and import to sheet cam. the good cut pic is if i bring it in 1:25. The messed up one is if i bring it in 1:1 cause i save the image the size i wanted in inkscape.
sho_me82
Post by sho_me82 »
acourtjester wrote: Wed Jan 06, 2021 12:56 pm When you import a drawing you can scale the drawing as shown in the image below. Now if you draw in inches and save in DXF you click on the inch box. If you save the drawing in SVG you scale it 1:1. What I see in your image is the small red box in the lower left and the screen if black. This is showing you have not selected the correct size of you material or work field. This is done in the setup of SheetCam see the attached images.
I have tried both ways and if i bring it in 1:1 its the messed up cut file. But when i bring it in 1:24 its the good one. I understand the red box sizing that is the actual size of my table. if i bring it in at 1:25 it makes it roughly 334" wide. 1:1 makes it the 24" that i have saved as in inkscape.
sho_me82
Post by sho_me82 »
AREA wrote: Wed Jan 06, 2021 10:25 am So it only does this when you scale down real small?
it only does it when i bring it in 1:1 its all messed up. 1:24 is fine but makes it 334" wide
how is it setup in Inkscape see attached image for inch, see image and size at the top of the page. What is yours?
scaling 5.JPG (63.14 KiB) Viewed 1213 times
sho_me82
Post by sho_me82 »
acourtjester wrote: Wed Jan 06, 2021 6:46 pm how is it setup in Inkscape see attached image for inch, see image and size at the top of the page. What is yours?
Yes that’s how it’s setup. Like I said if I bring it in 1:24 it’s fine just massive size. I even though well I’ll take the image to a smaller size got it down to 2”x1” and still same scenario
sho_me82
Post by sho_me82 »
Starting to think maybe the letters are to small? If that’s a possibility
that may be true, when looking at a drawing I always use the fill off and very thin path width of 0.005" then in SheetCam I have the "show true width" selected to see if the kerf will interfere with other cuts. If you want o post the original file I will look at it.
sho_me82
Post by sho_me82 »
I would but I've messed with it to the point I'm gonna have to reedit letters and go through the nodes again. I don't know is its me or just inkscape but i have to edit every letter because of rogue nodes lol
sho_me82
Post by sho_me82 »
usa solider flag UPDATED CHAD 24 X 14.svg
(23.24 KiB) Downloaded 60 times
There is some strange things with this. First as I have said before some fonts do not cut as they are shown, look at the "O". Another thing is I don't know why but the inside and outside offsets are reversed look at attached images. I would remove the text and replace it with another font, but check how they look before going to far.
usa 2.JPG (50.27 KiB) Viewed 1195 times
sho_me82
Post by sho_me82 »
So basically it’s just a none usable font? I’ve tried 3-4 different ones and they all do the same. On my sheetcam the e’s are messed up
sho_me82
Post by sho_me82 »
This is how it looks on my screen
sho_me82
Post by sho_me82 »
I made a video of changing the scale from 1:1 to 1:24 and everything was fine. Didn’t change anything but the scale size. I don’t know how to upload it though
If you zip the video you can post it here, or you can upload it to the Google drive (free for 15 GB) and then click to share it and you can get a address for anybody to view and post that here. like this
sho_me82
Post by sho_me82 »
I think i figured it out gonna try and cut it tomorrow maybe if i have time. I came across some overlaying nodes i deleted and the letting seemed a little better. I cut something tonight i had downloaded and it kinda looked messed up in my sheetcam but cut fine. Idk maybe my laptop dont have good enough vid car in it.
Something you may try is to crop the drawing to only have a small amount of the letters and run that through SheetCam and cut it. That way you know quickly if things are good or not. With your drawing in Inkscape using the node tool click on path then break apart.
select on ov the letters and hold down the shift key and select other letters to may 5 letter together. Now go to edit and select copy, then open a new Inkscape and paste those letters. save and make a G-code in SheetCam of those and cut them to check if OK .
usa 10.jpg (24.29 KiB) Viewed 1182 times
usa 12.jpg (17.21 KiB) Viewed 1182 times
sho_me82
Post by sho_me82 »
acourtjester wrote: Fri Jan 08, 2021 10:53 am Something you may try is to crop the drawing to only have a small amount of the letters and run that through SheetCam and cut it. That way you know quickly if things are good or not. With your drawing in Inkscape using the node tool click on path then break apart.
nice thanks for the info. im about to head to garage but dont know if ill get to this tonight or not.
Return to “Inkscape”
