I have never understood this setting in Mach3. Seems to be counter intuitive.
Art Fennerty (Mach3 creator) always had a somewhat haphazard way of naming settings etc in Mach3
That is not to disparage the man. I will always be thankful for the part he played in me getting started in CNC all those years ago.
This pic is borrowed from acourtjester. Hope you don't mind.
Don't understand this setting Mach3
- Attachments
- torch fire 2.JPG (56.84 KiB) Viewed 452 times
Re: Don't understand this setting Mach3
Not real familiar with mach but maybe it gives you the ability to jog the Z up and down manually while cutting with the auto torch height control turned off
- East German
You can control it by hand when the THC is off. This means that an external height control with cutting rules can be implemented very well.
I've used it for many years.
Peter
Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
Thanks for the reply.
Does that mean that you can vary the height of the Z axis, while cuts are happening and THC is turned off, by another method.
Some sort of manual torch height control.
For example, do a manual torch height adjustment whilst a cut is happening, via say a keyboard input.
