Hi all, my swift cut mark 3 won’t reference in the y axis anymore since I accidentally drove it hard into the bottom of the table. It will only run on one side when I press the y button and twists off. Both motors still work fine and it will cut ok still. It just won’t reference anymore? I can’t remember the fault code that came up but it was something like check home switch. Any thoughts?? I’ve tried turning it off and on again....
Rich
Won’t reference in the Y axis
Re: Won’t reference in the Y axis
Maybe test your home limit switch.
I'm with David, a quick test of your limit switch would be the best place to start. Its possible your software has an indicator that lights up on the screen when the switches are pressed, if not a multimeter will get the job done.
