Torch turns on during travel
Re: Torch turns on during travel
for ''Z'' steps are at 19980.70738/ velocity 13.998/ acceleration at 75. F is at 150 in the "Test" piece that I have been using. The Test piece is a simple rectangle with a 1/2'' hole in it.
I am about to throw this controller under the truck and start over. You stated that you went with the UC400ETH. Outside of purchacing this controller and Ethernet cable. What else would I need? Right now I have 35ish individual wires that connect the limits, motors, and spindle to this controller. I also see there is 2-26 pin connectors to plug a ribbon into the UC controller. Could you possibly give me a little parts list to help take the guess work out of buying the parts for the change over?acourtjester wrote: ↑Sat Sep 12, 2020 7:57 pm That came from the CNCzone post I'm sure it's old and that is why it did not open.
this is what I bought and I use a Post Processor for SheetCam for the Price THC I have, There are other ones that will work with this setup. https://www.automationtechnologiesinc.c ... ontroller/
You can download their software and other info from the web to get it running, they have to different looking screens you can use, I use the newer one (1.2112).
Have fun
Tom
Ok you need a BOB (or 2) that have the 24 pin Parallel Printer cable connector as its input. and a 12 or 24 volt supply for power to the unit.
The BOBs have a USB connecter for +5 volts input from you computer (only) no signals used with that. All the connections from the drivers and limit/home switches are hooked to the BOB per the BOB's manual. I use a single BOB and run all limit and home switches in series (one input pin) the ohmic sensor (another input pin) and the 3 pins from the THC (arc OK, up, and down). Most BOB have signal pins for 5 motors.
The ether cable connects to the computers ether (cat 5 input) for all the signals between the BOB and computer. The kit I bought came with a connector cable between the BOB and the 400ETH, and I bought an extra. You can hook 2 BOBs to the unit if you like to have more input/output signals, I use only one BOB works just fine.
Send me a PM with your email address and I will supply you with more info.
Thanks for your help. I was able to modify the commands in the post processor to make it do what I want each time I run post processor threw sheetcam. Added couple dwells here and there and also added another line to have the computer turn on and off my exhaust fans for the table.
Great work! Glad to hear you've got your problem solved.Rcmcustoms wrote: ↑Mon Sep 28, 2020 9:20 am Thanks for your help. I was able to modify the commands in the post processor to make it do what I want each time I run post processor threw sheetcam. Added couple dwells here and there and also added another line to have the computer turn on and off my exhaust fans for the table.
are you running a novuson control board it sound s like the problems I have will not cut a complete open line and will only cut a closed one if you overcut 1.5 inches
So if your missing a part of the line is it a section of line at the start or end of the cut?
Could simply be the torch is beginning to move before the torch has pierced the material. Have seen people pull their hair our over that when all that was needed was more pierce delay.
I was running a test piece with 4 inch straight cuts and it cut half a line unless the feed rate was faster it cut a little shorter than the next
torch turns off but it continues with the line until the end
Strange. What plasma cutter are you using? Any error codes on the plasma cutter when this happens?
Mach3 turns the torch off if I remove the m5 it will cut until the middle of the next line it’s like it’s reading ahead too fast hobart
can you upload your mach3 profile (*.pro), you may need to rename it to txt
Code: Select all
0010 (Filename: 4 linetest21.tap)
N0020 (Post processor: Mach3 THC with scriber.scpost)
N0030 (Date: 09/01/2022)
N0040 G20 (Units: Inches)
N0050 F1
N0060 G53 G90 G40
N0070 (Part: 4 linetest2)
N0080 (Operation: No Offset, 2, T1: Plasma, 0.0591 in kerf)
N0090 G00 X0.4357 Y0.4794
N0100 G28.1 Z0.12 F19.685
N0110 G92 Z0.0
N0120 G00 Z0.2199
N0130 G92 Z0.0
N0140 G00 Z0.1000
N0150 M03
N0160 G04 P0.5
N0170 G01 Z0.0900 F3.937
N0180 X4.4268 Y0.4341 F113.0
N0190 X4.4203 Y0.4492
N0200 (Operation: No Offset, 3, T1: Plasma, 0.0591 in kerf)
N0210 M05
N0220 G04 P0.2
N0230 G00 Z1.5000
N0240 X0.4216 Y0.9853
N0250 G28.1 Z0.12 F19.685
N0260 G92 Z0.0
N0270 G00 Z0.2199
N0280 G92 Z0.0
N0290 G00 Z0.1000
N0300 M03
N0310 G04 P0.5
N0320 G01 Z0.0900 F3.937
N0330 X4.4127 Y0.9400 F113.0
N0340 X4.4063 Y0.9551
N0350 (Operation: No Offset, 4, T1: Plasma, 0.0591 in kerf)
N0360 M05
N0370 G04 P0.2
N0380 G00 Z1.5000
N0390 X0.4357 Y1.5475
N0400 G28.1 Z0.12 F19.685
N0410 G92 Z0.0
N0420 G00 Z0.2199
N0430 G92 Z0.0
N0440 G00 Z0.1000
N0450 M03
N0460 G04 P0.5
N0470 G01 Z0.0900 F3.937
N0480 X4.4268 Y1.5022 F112.0
N0490 X4.4203 Y1.5173
N0500 (Operation: No Offset, 5, T1: Plasma, 0.0591 in kerf)
N0510 M05
N0520 G04 P0.2
N0530 G00 Z1.5000
N0540 X0.4357 Y2.0956
N0550 G28.1 Z0.12 F19.685
N0560 G92 Z0.0
N0570 G00 Z0.2199
N0580 G92 Z0.0
N0590 G00 Z0.1000
N0600 M03
N0610 G04 P0.5
N0620 G01 Z0.0900 F3.937
N0630 X4.4268 Y2.0503 F113.0
N0640 X4.4203 Y2.0654
N0650 (Operation: No Offset, 6, T1: Plasma, 0.0591 in kerf)
N0660 M05
N0670 G04 P0.2
N0680 G00 Z1.5000
N0690 X0.4497 Y2.5453
N0700 G28.1 Z0.12 F19.685
N0710 G92 Z0.0
N0720 G00 Z0.2199
N0730 G92 Z0.0
N0740 G00 Z0.1000
N0750 M03
N0760 G04 P0.5
N0770 G01 Z0.0900 F3.937
N0780 X4.4408 Y2.5000 F113.0
N0790 X4.4344 Y2.5151
N0800 (Operation: No Offset, 7, T1: Plasma, 0.0591 in kerf)
N0810 M05
N0820 G04 P0.2
N0830 G00 Z1.5000
N0840 X0.4919 Y3.0372
N0850 G28.1 Z0.12 F19.685
N0860 G92 Z0.0
N0870 G00 Z0.2199
N0880 G92 Z0.0
N0890 G00 Z0.1000
N0900 M03
N0910 G04 P0.5
N0920 G01 Z0.0900 F3.937
N0930 X4.4830 Y2.9919 F120.0
N0940 X4.4765 Y3.0070
N0950 (Operation: Outside Offset, layer1, T1: Plasma, 0.0591 in kerf)
N0960 M05
N0970 G04 P0.2
N0980 G00 Z1.5000
N0990 X4.6393 Y0.0000
N1000 G28.1 Z0.12 F19.685
N1010 G92 Z0.0
N1020 G00 Z0.2199
N1030 G92 Z0.0
N1040 G00 Z0.1000
N1050 M03
N1060 G04 P0.5
N1070 G01 Z0.0900 F3.937
N1080 G02 X4.6097 Y-0.0296 I-0.0295 J0.0000 F113.0
N1090 G01 X0.0000
N1100 G02 X-0.0296 Y0.0000 I0.0000 J0.0296
N1110 G01 Y3.6400
N1120 G02 X0.0000 Y3.6695 I0.0296 J0.0000
N1130 G01 X4.6097
N1140 G02 X4.6393 Y3.6400 I0.0000 J-0.0296
N1150 G01 Y0.0000
N1160 G02 X4.6097 Y-0.0296 I-0.0295 J0.0000
N1170 G01 X2.6561
N1180 M05
N1190 G04 P0.2
N1200 G00 Z1.5000
N1210 X0.0000 Y0.0000
N1220 M05 M30
Code: Select all
<?xml version="1.0"?>
-<profile>
-<Preferences>
<Syskey1>1</Syskey1>
<DefDir>D:\Mach3</DefDir>
<Profile>Plasma</Profile>
<NewPath>0</NewPath>
<BR>0.</BR>
<BG>0.</BG>
<BB>0.</BB>
<FR>0.</FR>
<FG>0.</FG>
<FB>1.</FB>
<RR>1.</RR>
<RG>0.</RG>
<RB>0.</RB>
<AR>0.7</AR>
<AG>0.2</AG>
<AB>0.7</AB>
<ER>1.</ER>
<EG>1.</EG>
<EB>0.</EB>
<MatRed>0.</MatRed>
<MatGreen>0.1</MatGreen>
<MatBlue>0.1</MatBlue>
<Running>0</Running>
<FirstRun>1</FirstRun>
<LastUser>Jerry B UPID</LastUser>
<Layout>Plasma.set</Layout>
<Motor0Active>1</Motor0Active>
<Motor0DirNeg>0</Motor0DirNeg>
<Motor0DirPort>1</Motor0DirPort>
<Motor0DirPin>0</Motor0DirPin>
<Motor0StepNeg>0</Motor0StepNeg>
<Motor0StepPort>1</Motor0StepPort>
<Motor0StepPin>0</Motor0StepPin>
<Motor1Active>1</Motor1Active>
<Motor1DirNeg>0</Motor1DirNeg>
<Motor1DirPort>1</Motor1DirPort>
<Motor1DirPin>0</Motor1DirPin>
<Motor1StepNeg>0</Motor1StepNeg>
<Motor1StepPort>1</Motor1StepPort>
<Motor1StepPin>0</Motor1StepPin>
<Motor2Active>1</Motor2Active>
<Motor2DirNeg>0</Motor2DirNeg>
<Motor2DirPort>1</Motor2DirPort>
<Motor2DirPin>0</Motor2DirPin>
<Motor2StepNeg>0</Motor2StepNeg>
<Motor2StepPort>1</Motor2StepPort>
<Motor2StepPin>0</Motor2StepPin>
<Motor3Active>1</Motor3Active>
<Motor3DirNeg>1</Motor3DirNeg>
<Motor3DirPort>1</Motor3DirPort>
<Motor3DirPin>0</Motor3DirPin>
<Motor3StepNeg>0</Motor3StepNeg>
<Motor3StepPort>1</Motor3StepPort>
<Motor3StepPin>0</Motor3StepPin>
<Motor4Active>0</Motor4Active>
<Motor4DirNeg>0</Motor4DirNeg>
<Motor4DirPort>0</Motor4DirPort>
<Motor4DirPin>0</Motor4DirPin>
<Motor4StepNeg>0</Motor4StepNeg>
<Motor4StepPort>0</Motor4StepPort>
<Motor4StepPin>0</Motor4StepPin>
<Motor5Active>0</Motor5Active>
<Motor5DirNeg>0</Motor5DirNeg>
<Motor5DirPort>0</Motor5DirPort>
<Motor5DirPin>0</Motor5DirPin>
<Motor5StepNeg>0</Motor5StepNeg>
<Motor5StepPort>0</Motor5StepPort>
<Motor5StepPin>0</Motor5StepPin>
<Motor6Active>0</Motor6Active>
<Motor6DirNeg>0</Motor6DirNeg>
<Motor6DirPort>0</Motor6DirPort>
<Motor6DirPin>0</Motor6DirPin>
<Motor6StepNeg>0</Motor6StepNeg>
<Motor6StepPort>0</Motor6StepPort>
<Motor6StepPin>0</Motor6StepPin>
<Serial>0</Serial>
<SerialServo>0</SerialServo>
<Port2Input>0</Port2Input>
<GeckoMode>0</GeckoMode>
<USBINPUTS>16</USBINPUTS>
<USBOUTPUTS>16</USBOUTPUTS>
<Port2On>1</Port2On>
<Port1On>1</Port1On>
<Port1Add>888</Port1Add>
<Port2Add>632</Port2Add>
<PulseSpeed>4</PulseSpeed>
<MaxCL>0</MaxCL>
<MaxNC10>0</MaxNC10>
<ModPlug>0</ModPlug>
<TCPMODBUS>0</TCPMODBUS>
<Configured>1</Configured>
<m_SafeZ>2.</m_SafeZ>
<CVUseAngle>1</CVUseAngle>
<CVDegrees>4.e-002</CVDegrees>
<Steps6>1.</Steps6>
<M9After>0</M9After>
<DwellTrigger>0</DwellTrigger>
<IgnoreMacros>0</IgnoreMacros>
<ZBar>1</ZBar>
<ROTSOFT>1</ROTSOFT>
<PROBETLO>0</PROBETLO>
<SlaveHome>1</SlaveHome>
<LockFROs>1</LockFROs>
<JogHeat>0</JogHeat>
<KeyClick>0</KeyClick>
<THC5>1</THC5>
<SpinInc>0</SpinInc>
<M30SpinOff>0</M30SpinOff>
<AutoCalcs>0</AutoCalcs>
<Boxed>1</Boxed>
<SafeZStop>1</SafeZStop>
<SafeZType>1</SafeZType>
<UseDiam>0</UseDiam>
<ToolLines>0</ToolLines>
<NURBS>1</NURBS>
<ToolPersist>0</ToolPersist>
<KeepRef>0</KeepRef>
<TurnRevArc>1</TurnRevArc>
<TORCHVON>0</TORCHVON>
<TORCHVOLTS>0</TORCHVOLTS>
<HWSAFE>1</HWSAFE>
<ShortRot>0</ShortRot>
<LookAhead>200</LookAhead>
<WatchDog>1</WatchDog>
<Plane>0</Plane>
<MPG1>0</MPG1>
<MPG2>0</MPG2>
<HotKeysPersist>0</HotKeysPersist>
<HoldInput1>0</HoldInput1>
<M3s>3948</M3s>
<HiRes>0</HiRes>
<UseCR>0</UseCR>
<DelinChar>12</DelinChar>
<PlasmaHome>0</PlasmaHome>
<Rot360>0</Rot360>
<Homann>0</Homann>
<UseSLS>0</UseSLS>
<UDP>0</UDP>
<DROFont>Arial</DROFont>
<LabelFont>Arial</LabelFont>
<CodeFont>Arial</CodeFont>
<ButtonFont>Arial</ButtonFont>
<Dist0>2.4e+004</Dist0>
<Dist1>2.4e+004</Dist1>
<Dist2>1.e+004</Dist2>
<Dist3>5.6</Dist3>
<Dist4>0.</Dist4>
<Dist5>0.</Dist5>
<OverMode2>0</OverMode2>
<BitPack1>0</BitPack1>
<BitPack1Reg>16</BitPack1Reg>
<BitPackOut>0</BitPackOut>
<BitPackOutReg>16</BitPackOutReg>
<LaserPort>1</LaserPort>
<LaserBaud>9600</LaserBaud>
<LaserStops>1</LaserStops>
<LaserData>1</LaserData>
<LaserInit>></LaserInit>
<LaserCommand>></LaserCommand>
<MacroPump>0</MacroPump>
<PierceDelay>1.</PierceDelay>
<M7Delay>0.</M7Delay>
<M8Delay>0.</M8Delay>
<VelMode>0</VelMode>
<VelPer1>5.</VelPer1>
<VelPer2>5.</VelPer2>
<VelPer3>5.</VelPer3>
<TouchX>0.</TouchX>
<G20X>0.</G20X>
<G20Y>0.</G20Y>
<G20Z>0.</G20Z>
<G20A>0.</G20A>
<G20B>0.</G20B>
<G20C>0.</G20C>
<MPGFeed>1.e+002</MPGFeed>
<ModSpindleCal>1.638e+004</ModSpindleCal>
<ModSpindleOn>0</ModSpindleOn>
<ModSpindleReg>64</ModSpindleReg>
<ShuttleAccel>512000</ShuttleAccel>
<Flash>1</Flash>
<ImmediateOff>1</ImmediateOff>
<UseSafeZ>1</UseSafeZ>
<AdvancedComp>1</AdvancedComp>
<TorchOff>0</TorchOff>
<LaserStandby>0</LaserStandby>
<RaiseLower>1</RaiseLower>
<OEMDUAL>0</OEMDUAL>
<IncBuffer>5</IncBuffer>
<Formula0>x</Formula0>
<Formula1>y</Formula1>
<Formula2>z</Formula2>
<Formula3>a</Formula3>
<Formula4>b</Formula4>
<Formula5>c</Formula5>
<Formular>0</Formular>
<PanelOut>479</PanelOut>
<nModBusReg>0</nModBusReg>
<ModBusRegOn>0</ModBusRegOn>
<Tool>0</Tool>
<Sherline>0</Sherline>
<ToolPost>1</ToolPost>
<RapidOverRide>0</RapidOverRide>
<XCLength>1.3e+003</XCLength>
<YCLength>1.3e+003</YCLength>
<ZCLength>1.3e+003</ZCLength>
<ToolPostOffset>0.</ToolPostOffset>
<FrontRear>0.</FrontRear>
<OEM1>-1</OEM1>
<OEM2>-1</OEM2>
<OEM3>-1</OEM3>
<OEM4>-1</OEM4>
<OEM5>-1</OEM5>
<OEM6>-1</OEM6>
<OEM7>-1</OEM7>
<OEM8>-1</OEM8>
<OEM9>-1</OEM9>
<OEM10>-1</OEM10>
<OEM11>-1</OEM11>
<OEM12>-1</OEM12>
<OEM13>-1</OEM13>
<OEM14>-1</OEM14>
<OEM15>-1</OEM15>
<MPGVel0>1.e+002</MPGVel0>
<MPGVel1>1.e+002</MPGVel1>
<MPGVel2>1.e+002</MPGVel2>
<MPGVel3>1.e+002</MPGVel3>
<MPGVel4>1.e+002</MPGVel4>
<MPGVel5>1.e+002</MPGVel5>
<MPGVel6>1.e+002</MPGVel6>
<ByPassFeed>1.e+003</ByPassFeed>
<XMapOn>0</XMapOn>
<YMapOn>0</YMapOn>
<ZMapOn>0</ZMapOn>
<SecondsOn>1078918</SecondsOn>
<SerialType>0</SerialType>
<SpinAverage>0</SpinAverage>
<Dig4Axis>0</Dig4Axis>
<DigLetter>0</DigLetter>
<CutType>0</CutType>
<InfeedType>0</InfeedType>
<LastWizard>None</LastWizard>
<Z25D>0</Z25D>
<ModBus>0</ModBus>
<ChargeAlwaysOn>0</ChargeAlwaysOn>
<ToolFlip>0</ToolFlip>
<SpinCCW>8</SpinCCW>
<SpinCW>9</SpinCW>
<Flood>10</Flood>
<Mist>7</Mist>
<SpinActual>0</SpinActual>
<SpinDelayCW>0.</SpinDelayCW>
<SpinDelayCCW>0.</SpinDelayCCW>
<SpinDownCW>0.</SpinDownCW>
<SpinDownCCW>0.</SpinDownCCW>
<StockSize>50</StockSize>
<ShowSolid>1</ShowSolid>
<RapidFeed>1.e+003</RapidFeed>
<SpinP>0.25</SpinP>
<SpinI>1.</SpinI>
<SpinD>0.3</SpinD>
<SpinClosed>0</SpinClosed>
<MinPerPass>0.1</MinPerPass>
<NoSpindle>0</NoSpindle>
<NoFlood>0</NoFlood>
<PWMin>0</PWMin>
<PULLEY>3</PULLEY>
<PWM>0</PWM>
<SPEED1>25000</SPEED1>
<LSPEED1>0</LSPEED1>
<SPINREV1>0</SPINREV1>
<SPINRATIO1>1.</SPINRATIO1>
<SPEED2>25000</SPEED2>
<LSPEED2>0</LSPEED2>
<SPINREV2>0</SPINREV2>
<SPINRATIO2>1.</SPINRATIO2>
<SPEED3>25000</SPEED3>
<LSPEED3>0</LSPEED3>
<SPINREV3>0</SPINREV3>
<SPINRATIO3>1.</SPINRATIO3>
<SPEED4>25000</SPEED4>
<LSPEED4>0</LSPEED4>
<SPINREV4>0</SPINREV4>
<SPINRATIO4>1.</SPINRATIO4>
<SPEED5>25000</SPEED5>
<LSPEED5>0</LSPEED5>
<SPINREV5>0</SPINREV5>
<SPINRATIO5>1.</SPINRATIO5>
<SPEED6>25000</SPEED6>
<LSPEED6>0</LSPEED6>
<SPINREV6>0</SPINREV6>
<SPINRATIO6>1.</SPINRATIO6>
<SPEED7>25000</SPEED7>
<LSPEED7>0</LSPEED7>
<SPINREV7>0</SPINREV7>
<SPINRATIO7>1.</SPINRATIO7>
<SPEED8>25000</SPEED8>
<LSPEED8>0</LSPEED8>
<SPINREV8>0</SPINREV8>
<SPINRATIO8>1.</SPINRATIO8>
<SPEED9>25000</SPEED9>
<LSPEED9>0</LSPEED9>
<SPINREV9>0</SPINREV9>
<SPINRATIO9>1.</SPINRATIO9>
<SPEED10>25000</SPEED10>
<LSPEED10>0</LSPEED10>
<SPINREV10>0</SPINREV10>
<SPINRATIO10>1.</SPINRATIO10>
<SPEED11>25000</SPEED11>
<LSPEED11>0</LSPEED11>
<SPINREV11>0</SPINREV11>
<SPINRATIO11>1.</SPINRATIO11>
<SPEED12>25000</SPEED12>
<LSPEED12>0</LSPEED12>
<SPINREV12>0</SPINREV12>
<SPINRATIO12>1.</SPINRATIO12>
<SPEED13>25000</SPEED13>
<LSPEED13>0</LSPEED13>
<SPINREV13>0</SPINREV13>
<SPINRATIO13>1.</SPINRATIO13>
<SPEED14>25000</SPEED14>
<LSPEED14>0</LSPEED14>
<SPINREV14>0</SPINREV14>
<SPINRATIO14>1.</SPINRATIO14>
<SPEED15>25000</SPEED15>
<LSPEED15>0</LSPEED15>
<SPINREV15>0</SPINREV15>
<SPINRATIO15>1.</SPINRATIO15>
<SPEED16>25000</SPEED16>
<LSPEED16>0</LSPEED16>
<SPINREV16>0</SPINREV16>
<SPINRATIO16>1.</SPINRATIO16>
<SPEED17>25000</SPEED17>
<LSPEED17>0</LSPEED17>
<SPINREV17>0</SPINREV17>
<SPINRATIO17>1.</SPINRATIO17>
<SPEED18>25000</SPEED18>
<LSPEED18>0</LSPEED18>
<SPINREV18>0</SPINREV18>
<SPINRATIO18>1.</SPINRATIO18>
<SPEED19>25000</SPEED19>
<LSPEED19>0</LSPEED19>
<SPINREV19>0</SPINREV19>
<SPINRATIO19>1.</SPINRATIO19>
<SPEED20>25000</SPEED20>
<LSPEED20>0</LSPEED20>
<SPINREV20>0</SPINREV20>
<SPINRATIO20>1.</SPINRATIO20>
<SPEED21>25000</SPEED21>
<LSPEED21>0</LSPEED21>
<SPINREV21>0</SPINREV21>
<SPINRATIO21>1.</SPINRATIO21>
<SPEED22>25000</SPEED22>
<LSPEED22>0</LSPEED22>
<SPINREV22>0</SPINREV22>
<SPINRATIO22>1.</SPINRATIO22>
<SPEED23>25000</SPEED23>
<LSPEED23>0</LSPEED23>
<SPINREV23>0</SPINREV23>
<SPINRATIO23>1.</SPINRATIO23>
<SPEED24>25000</SPEED24>
<LSPEED24>0</LSPEED24>
<SPINREV24>0</SPINREV24>
<SPINRATIO24>1.</SPINRATIO24>
<SPEED25>25000</SPEED25>
<LSPEED25>0</LSPEED25>
<SPINREV25>0</SPINREV25>
<SPINRATIO25>1.</SPINRATIO25>
<RefSpeed0>80</RefSpeed0>
<RefSpeed1>80</RefSpeed1>
<RefSpeed2>80</RefSpeed2>
<RefSpeed3>80</RefSpeed3>
<RefSpeed4>20</RefSpeed4>
<RefSpeed5>20</RefSpeed5>
<M0SoftRamp>5.</M0SoftRamp>
<M1SoftRamp>4.</M1SoftRamp>
<M2SoftRamp>1.</M2SoftRamp>
<M3SoftRamp>1.</M3SoftRamp>
<M4SoftRamp>1.</M4SoftRamp>
<M5SoftRamp>1.</M5SoftRamp>
<FeedInc>5.</FeedInc>
<DepthLastPass>0.</DepthLastPass>
<InFeed>29.5</InFeed>
<Spring>1.</Spring>
<MinDepth>1.e-003</MinDepth>
<XClear>0.1</XClear>
<ZClear>0.1</ZClear>
<CutDepth>0.1</CutDepth>
<Chamfer>0.</Chamfer>
<DepthFirstPass>0.1</DepthFirstPass>
<M0Max>0.</M0Max>
<M1Max>0.</M1Max>
<M2Max>0.</M2Max>
<M3Max>0.</M3Max>
<M4Max>100.</M4Max>
<M5Max>100.</M5Max>
<M0Min>-61.</M0Min>
<M1Min>-57.</M1Min>
<M2Min>-6.5</M2Min>
<M3Min>0.</M3Min>
<M4Min>-100.</M4Min>
<M5Min>-100.</M5Min>
<M0Neg>0</M0Neg>
<M1Neg>0</M1Neg>
<M2Neg>0</M2Neg>
<M3Neg>0</M3Neg>
<M4Neg>0</M4Neg>
<M5Neg>0</M5Neg>
<M0Rev>0</M0Rev>
<M1Rev>0</M1Rev>
<M2Rev>0</M2Rev>
<M3Rev>0</M3Rev>
<M4Rev>0</M4Rev>
<M5Rev>0</M5Rev>
<M6Rev>0</M6Rev>
<OffPersist>1</OffPersist>
<Diameter>0</Diameter>
<OffDialogs>1</OffDialogs>
<G54Back>0</G54Back>
<GougeCheck>1</GougeCheck>
<AxisToMotor0>0</AxisToMotor0>
<AxisToMotor1>1</AxisToMotor1>
<AxisToMotor2>2</AxisToMotor2>
<AxisToMotor3>3</AxisToMotor3>
<AxisToMotor4>4</AxisToMotor4>
<AxisToMotor5>5</AxisToMotor5>
<AxisToMotor6>6</AxisToMotor6>
<JogActive>1</JogActive>
<BLState0>0</BLState0>
<BLState1>0</BLState1>
<BLState2>0</BLState2>
<BLState3>0</BLState3>
<BLState4>0</BLState4>
<BLState5>0</BLState5>
<SlowMode>0</SlowMode>
<JogPersist>1</JogPersist>
<ToolRotations>0</ToolRotations>
<SoftLimit>0</SoftLimit>
<JogMode>0</JogMode>
<EncJogAxis1>6</EncJogAxis1>
<EncJogAxis2>1</EncJogAxis2>
<EncJogAxis3>2</EncJogAxis3>
<TaperRatio>1.</TaperRatio>
<XStart>1518</XStart>
<YStart>-39296</YStart>
<ZStart>179022</ZStart>
<AStart>-79920</AStart>
<BStart>0</BStart>
<CStart>0</CStart>
<OVSpinInc>0</OVSpinInc>
<Enc0>0.</Enc0>
<Enc1>0.</Enc1>
<Enc2>0.</Enc2>
<Enc3>0.</Enc3>
<TangentalControl>0</TangentalControl>
<BaudRate>9600</BaudRate>
<ComPort>1</ComPort>
<NoPlunge>0</NoPlunge>
<PlungeLimit>60</PlungeLimit>
<AutoTool>0</AutoTool>
<AutoSpindle>0</AutoSpindle>
<LaserMode>0</LaserMode>
<FeedMode>0</FeedMode>
<AAngular>0</AAngular>
<BAngular>0</BAngular>
<CAngular>0</CAngular>
<OriginSphere>0</OriginSphere>
<m_3dCompass>1</m_3dCompass>
<Boundries>0</Boundries>
<ToolPosition>1</ToolPosition>
<AParallel>0</AParallel>
<ZINHPersist>0</ZINHPersist>
<OVPersist>1</OVPersist>
<BacklashOn>0</BacklashOn>
<ThrottleFunc>2</ThrottleFunc>
<JoyOn>0</JoyOn>
<PWMBase>5000</PWMBase>
<JogSpeed>100.</JogSpeed>
<G73PullBack>0.1</G73PullBack>
<CVFeedOn>0</CVFeedOn>
<CVFeedRate>1.</CVFeedRate>
<AtoX>0.</AtoX>
<AtoY>0.</AtoY>
<AtoZ>0.</AtoZ>
<OEMDRO0>0.</OEMDRO0>
<OEMLED0>0</OEMLED0>
<OEMDRO1>0.</OEMDRO1>
<OEMLED1>0</OEMLED1>
<OEMDRO2>0.</OEMDRO2>
<OEMLED2>0</OEMLED2>
<OEMDRO3>0.</OEMDRO3>
<OEMLED3>0</OEMLED3>
<OEMDRO4>0.</OEMDRO4>
<OEMLED4>0</OEMLED4>
<OEMDRO5>0.</OEMDRO5>
<OEMLED5>0</OEMLED5>
<OEMDRO6>0.</OEMDRO6>
<OEMLED6>0</OEMLED6>
<OEMDRO7>0.</OEMDRO7>
<OEMLED7>0</OEMLED7>
<OEMDRO8>0.</OEMDRO8>
<OEMLED8>0</OEMLED8>
<OEMDRO9>0.</OEMDRO9>
<OEMLED9>0</OEMLED9>
<OEMDRO10>0.</OEMDRO10>
<OEMLED10>0</OEMLED10>
<OEMDRO11>0.</OEMDRO11>
<OEMLED11>0</OEMLED11>
<OEMDRO12>0.</OEMDRO12>
<OEMLED12>0</OEMLED12>
<OEMDRO13>0.</OEMDRO13>
<OEMLED13>0</OEMLED13>
<OEMDRO14>0.</OEMDRO14>
<OEMLED14>0</OEMLED14>
<OEMDRO15>0.</OEMDRO15>
<OEMLED15>0</OEMLED15>
<OEMDRO16>0.</OEMDRO16>
<OEMLED16>0</OEMLED16>
<OEMDRO17>0.</OEMDRO17>
<OEMLED17>0</OEMLED17>
<OEMDRO18>0.</OEMDRO18>
<OEMLED18>0</OEMLED18>
<OEMDRO19>0.</OEMDRO19>
<OEMLED19>0</OEMLED19>
<OEMDRO20>0.</OEMDRO20>
<OEMLED20>0</OEMLED20>
<OEMDRO21>0.</OEMDRO21>
<OEMLED21>0</OEMLED21>
<OEMDRO22>0.</OEMDRO22>
<OEMLED22>0</OEMLED22>
<OEMDRO23>0.</OEMDRO23>
<OEMLED23>0</OEMLED23>
<OEMDRO24>0.</OEMDRO24>
<OEMLED24>0</OEMLED24>
<OEMDRO25>0.</OEMDRO25>
<OEMLED25>0</OEMLED25>
<OEMDRO26>0.</OEMDRO26>
<OEMLED26>0</OEMLED26>
<OEMDRO27>0.</OEMDRO27>
<OEMLED27>0</OEMLED27>
<OEMDRO28>0.</OEMDRO28>
<OEMLED28>0</OEMLED28>
<OEMDRO29>0.</OEMDRO29>
<OEMLED29>0</OEMLED29>
<OEMDRO30>0.</OEMDRO30>
<OEMLED30>0</OEMLED30>
<OEMDRO31>0.</OEMDRO31>
<OEMLED31>0</OEMLED31>
<OEMDRO32>0.</OEMDRO32>
<OEMLED32>0</OEMLED32>
<OEMDRO33>0.</OEMDRO33>
<OEMLED33>0</OEMLED33>
<OEMDRO34>0.</OEMDRO34>
<OEMLED34>0</OEMLED34>
<OEMDRO35>0.</OEMDRO35>
<OEMLED35>0</OEMLED35>
<OEMDRO36>0.</OEMDRO36>
<OEMLED36>0</OEMLED36>
<OEMDRO37>0.</OEMDRO37>
<OEMLED37>0</OEMLED37>
<OEMDRO38>0.</OEMDRO38>
<OEMLED38>0</OEMLED38>
<OEMDRO39>0.</OEMDRO39>
<OEMLED39>0</OEMLED39>
<OEMDRO40>0.</OEMDRO40>
<OEMLED40>0</OEMLED40>
<OEMDRO41>0.</OEMDRO41>
<OEMLED41>0</OEMLED41>
<OEMDRO42>0.</OEMDRO42>
<OEMLED42>0</OEMLED42>
<OEMDRO43>0.</OEMDRO43>
<OEMLED43>0</OEMLED43>
<OEMDRO44>0.</OEMDRO44>
<OEMLED44>0</OEMLED44>
<OEMDRO45>0.</OEMDRO45>
<OEMLED45>0</OEMLED45>
<OEMDRO46>0.</OEMDRO46>
<OEMLED46>0</OEMLED46>
<OEMDRO47>0.</OEMDRO47>
<OEMLED47>0</OEMLED47>
<OEMDRO48>0.</OEMDRO48>
<OEMLED48>0</OEMLED48>
<OEMDRO49>0.</OEMDRO49>
<OEMLED49>0</OEMLED49>
<OEMDRO50>0.</OEMDRO50>
<OEMLED50>0</OEMLED50>
<OEMDRO51>0.</OEMDRO51>
<OEMLED51>0</OEMLED51>
<OEMDRO52>0.</OEMDRO52>
<OEMLED52>0</OEMLED52>
<OEMDRO53>0.</OEMDRO53>
<OEMLED53>0</OEMLED53>
<OEMDRO54>0.</OEMDRO54>
<OEMLED54>0</OEMLED54>
<OEMDRO55>0.</OEMDRO55>
<OEMLED55>0</OEMLED55>
<OEMDRO56>0.</OEMDRO56>
<OEMLED56>0</OEMLED56>
<OEMDRO57>0.</OEMDRO57>
<OEMLED57>0</OEMLED57>
<OEMDRO58>0.</OEMDRO58>
<OEMLED58>0</OEMLED58>
<OEMDRO59>0.</OEMDRO59>
<OEMLED59>0</OEMLED59>
<OEMDRO60>0.</OEMDRO60>
<OEMLED60>0</OEMLED60>
<OEMDRO61>0.</OEMDRO61>
<OEMLED61>0</OEMLED61>
<OEMDRO62>0.</OEMDRO62>
<OEMLED62>0</OEMLED62>
<OEMDRO63>0.</OEMDRO63>
<OEMLED63>0</OEMLED63>
<OEMDRO64>0.</OEMDRO64>
<OEMLED64>0</OEMLED64>
<OEMDRO65>0.</OEMDRO65>
<OEMLED65>0</OEMLED65>
<OEMDRO66>0.</OEMDRO66>
<OEMLED66>0</OEMLED66>
<OEMDRO67>0.</OEMDRO67>
<OEMLED67>0</OEMLED67>
<OEMDRO68>0.</OEMDRO68>
<OEMLED68>0</OEMLED68>
<OEMDRO69>0.</OEMDRO69>
<OEMLED69>0</OEMLED69>
<OEMDRO70>0.</OEMDRO70>
<OEMLED70>0</OEMLED70>
<OEMDRO71>0.</OEMDRO71>
<OEMLED71>0</OEMLED71>
<OEMDRO72>0.</OEMDRO72>
<OEMLED72>0</OEMLED72>
<OEMDRO73>0.</OEMDRO73>
<OEMLED73>0</OEMLED73>
<OEMDRO74>0.</OEMDRO74>
<OEMLED74>0</OEMLED74>
<OEMDRO75>0.</OEMDRO75>
<OEMLED75>0</OEMLED75>
<OEMDRO76>0.</OEMDRO76>
<OEMLED76>0</OEMLED76>
<OEMDRO77>0.</OEMDRO77>
<OEMLED77>0</OEMLED77>
<OEMDRO78>0.</OEMDRO78>
<OEMLED78>0</OEMLED78>
<OEMDRO79>0.</OEMDRO79>
<OEMLED79>0</OEMLED79>
<OEMDRO80>0.</OEMDRO80>
<OEMLED80>0</OEMLED80>
<OEMDRO81>0.</OEMDRO81>
<OEMLED81>0</OEMLED81>
<OEMDRO82>0.</OEMDRO82>
<OEMLED82>0</OEMLED82>
<OEMDRO83>0.</OEMDRO83>
<OEMLED83>0</OEMLED83>
<OEMDRO84>0.</OEMDRO84>
<OEMLED84>0</OEMLED84>
<OEMDRO85>0.</OEMDRO85>
<OEMLED85>0</OEMLED85>
<OEMDRO86>0.</OEMDRO86>
<OEMLED86>0</OEMLED86>
<OEMDRO87>0.</OEMDRO87>
<OEMLED87>0</OEMLED87>
<OEMDRO88>0.</OEMDRO88>
<OEMLED88>0</OEMLED88>
<OEMDRO89>0.</OEMDRO89>
<OEMLED89>0</OEMLED89>
<OEMDRO90>0.</OEMDRO90>
<OEMLED90>0</OEMLED90>
<OEMDRO91>0.</OEMDRO91>
<OEMLED91>0</OEMLED91>
<OEMDRO92>0.</OEMDRO92>
<OEMLED92>0</OEMLED92>
<OEMDRO93>0.</OEMDRO93>
<OEMLED93>0</OEMLED93>
<OEMDRO94>0.</OEMDRO94>
<OEMLED94>0</OEMLED94>
<OEMDRO95>0.</OEMDRO95>
<OEMLED95>0</OEMLED95>
<OEMDRO96>0.</OEMDRO96>
<OEMLED96>0</OEMLED96>
<OEMDRO97>0.</OEMDRO97>
<OEMLED97>0</OEMLED97>
<OEMDRO98>0.</OEMDRO98>
<OEMLED98>0</OEMLED98>
<OEMDRO99>0.</OEMDRO99>
<OEMLED99>0</OEMLED99>
<OEMDRO100>0.</OEMDRO100>
<OEMLED100>0</OEMLED100>
<OEMDRO101>0.</OEMDRO101>
<OEMLED101>0</OEMLED101>
<OEMDRO102>0.</OEMDRO102>
<OEMLED102>0</OEMLED102>
<OEMDRO103>0.</OEMDRO103>
<OEMLED103>0</OEMLED103>
<OEMDRO104>0.</OEMDRO104>
<OEMLED104>0</OEMLED104>
<OEMDRO105>0.</OEMDRO105>
<OEMLED105>0</OEMLED105>
<OEMDRO106>0.</OEMDRO106>
<OEMLED106>0</OEMLED106>
<OEMDRO107>0.</OEMDRO107>
<OEMLED107>0</OEMLED107>
<OEMDRO108>0.</OEMDRO108>
<OEMLED108>0</OEMLED108>
<OEMDRO109>0.</OEMDRO109>
<OEMLED109>0</OEMLED109>
<OEMDRO110>0.</OEMDRO110>
<OEMLED110>0</OEMLED110>
<OEMDRO111>0.</OEMDRO111>
<OEMLED111>0</OEMLED111>
<OEMDRO112>0.</OEMDRO112>
<OEMLED112>0</OEMLED112>
<OEMDRO113>0.</OEMDRO113>
<OEMLED113>0</OEMLED113>
<OEMDRO114>0.</OEMDRO114>
<OEMLED114>0</OEMLED114>
<OEMDRO115>0.</OEMDRO115>
<OEMLED115>0</OEMLED115>
<OEMDRO116>0.</OEMDRO116>
<OEMLED116>0</OEMLED116>
<OEMDRO117>0.</OEMDRO117>
<OEMLED117>0</OEMLED117>
<OEMDRO118>0.</OEMDRO118>
<OEMLED118>0</OEMLED118>
<OEMDRO119>0.</OEMDRO119>
<OEMLED119>0</OEMLED119>
<OEMDRO120>0.</OEMDRO120>
<OEMLED120>0</OEMLED120>
<OEMDRO121>0.</OEMDRO121>
<OEMLED121>0</OEMLED121>
<OEMDRO122>0.</OEMDRO122>
<OEMLED122>0</OEMLED122>
<OEMDRO123>0.</OEMDRO123>
<OEMLED123>0</OEMLED123>
<OEMDRO124>0.</OEMDRO124>
<OEMLED124>0</OEMLED124>
<OEMDRO125>0.</OEMDRO125>
<OEMLED125>0</OEMLED125>
<OEMDRO126>0.</OEMDRO126>
<OEMLED126>0</OEMLED126>
<OEMDRO127>0.</OEMDRO127>
<OEMLED127>0</OEMLED127>
<OEMDRO128>0.</OEMDRO128>
<OEMLED128>0</OEMLED128>
<OEMDRO129>0.</OEMDRO129>
<OEMLED129>0</OEMLED129>
<OEMDRO130>0.</OEMDRO130>
<OEMLED130>0</OEMLED130>
<OEMDRO131>0.</OEMDRO131>
<OEMLED131>0</OEMLED131>
<OEMDRO132>0.</OEMDRO132>
<OEMLED132>0</OEMLED132>
<OEMDRO133>0.</OEMDRO133>
<OEMLED133>0</OEMLED133>
<OEMDRO134>0.</OEMDRO134>
<OEMLED134>0</OEMLED134>
<OEMDRO135>0.</OEMDRO135>
<OEMLED135>0</OEMLED135>
<OEMDRO136>0.</OEMDRO136>
<OEMLED136>0</OEMLED136>
<OEMDRO137>0.</OEMDRO137>
<OEMLED137>0</OEMLED137>
<OEMDRO138>0.</OEMDRO138>
<OEMLED138>0</OEMLED138>
<OEMDRO139>0.</OEMDRO139>
<OEMLED139>0</OEMLED139>
<OEMDRO140>0.</OEMDRO140>
<OEMLED140>0</OEMLED140>
<OEMDRO141>0.</OEMDRO141>
<OEMLED141>0</OEMLED141>
<OEMDRO142>0.</OEMDRO142>
<OEMLED142>0</OEMLED142>
<OEMDRO143>0.</OEMDRO143>
<OEMLED143>0</OEMLED143>
<OEMDRO144>0.</OEMDRO144>
<OEMLED144>0</OEMLED144>
<OEMDRO145>0.</OEMDRO145>
<OEMLED145>0</OEMLED145>
<OEMDRO146>0.</OEMDRO146>
<OEMLED146>0</OEMLED146>
<OEMDRO147>0.</OEMDRO147>
<OEMLED147>0</OEMLED147>
<OEMDRO148>0.</OEMDRO148>
<OEMLED148>0</OEMLED148>
<OEMDRO149>0.</OEMDRO149>
<OEMLED149>0</OEMLED149>
<OEMDRO150>0.</OEMDRO150>
<OEMLED150>0</OEMLED150>
<OEMDRO151>0.</OEMDRO151>
<OEMLED151>0</OEMLED151>
<OEMDRO152>0.</OEMDRO152>
<OEMLED152>0</OEMLED152>
<OEMDRO153>0.</OEMDRO153>
<OEMLED153>0</OEMLED153>
<OEMDRO154>0.</OEMDRO154>
<OEMLED154>0</OEMLED154>
<OEMDRO155>0.</OEMDRO155>
<OEMLED155>0</OEMLED155>
<OEMDRO156>0.</OEMDRO156>
<OEMLED156>0</OEMLED156>
<OEMDRO157>0.</OEMDRO157>
<OEMLED157>0</OEMLED157>
<OEMDRO158>0.</OEMDRO158>
<OEMLED158>0</OEMLED158>
<OEMDRO159>0.</OEMDRO159>
<OEMLED159>0</OEMLED159>
<OEMDRO160>0.</OEMDRO160>
<OEMLED160>0</OEMLED160>
<OEMDRO161>0.</OEMDRO161>
<OEMLED161>0</OEMLED161>
<OEMDRO162>0.</OEMDRO162>
<OEMLED162>0</OEMLED162>
<OEMDRO163>0.</OEMDRO163>
<OEMLED163>0</OEMLED163>
<OEMDRO164>0.</OEMDRO164>
<OEMLED164>0</OEMLED164>
<OEMDRO165>0.</OEMDRO165>
<OEMLED165>0</OEMLED165>
<OEMDRO166>0.</OEMDRO166>
<OEMLED166>0</OEMLED166>
<OEMDRO167>0.</OEMDRO167>
<OEMLED167>0</OEMLED167>
<OEMDRO168>0.</OEMDRO168>
<OEMLED168>0</OEMLED168>
<OEMDRO169>0.</OEMDRO169>
<OEMLED169>0</OEMLED169>
<OEMDRO170>0.</OEMDRO170>
<OEMLED170>0</OEMLED170>
<OEMDRO171>0.</OEMDRO171>
<OEMLED171>0</OEMLED171>
<OEMDRO172>0.</OEMDRO172>
<OEMLED172>0</OEMLED172>
<OEMDRO173>0.</OEMDRO173>
<OEMLED173>0</OEMLED173>
<OEMDRO174>0.</OEMDRO174>
<OEMLED174>0</OEMLED174>
<OEMDRO175>0.</OEMDRO175>
<OEMLED175>0</OEMLED175>
<OEMDRO176>0.</OEMDRO176>
<OEMLED176>0</OEMLED176>
<OEMDRO177>0.</OEMDRO177>
<OEMLED177>0</OEMLED177>
<OEMDRO178>0.</OEMDRO178>
<OEMLED178>0</OEMLED178>
<OEMDRO179>0.</OEMDRO179>
<OEMLED179>0</OEMLED179>
<OEMDRO180>0.</OEMDRO180>
<OEMLED180>0</OEMLED180>
<OEMDRO181>0.</OEMDRO181>
<OEMLED181>0</OEMLED181>
<OEMDRO182>0.</OEMDRO182>
<OEMLED182>0</OEMLED182>
<OEMDRO183>0.</OEMDRO183>
<OEMLED183>0</OEMLED183>
<OEMDRO184>0.</OEMDRO184>
<OEMLED184>0</OEMLED184>
<OEMDRO185>0.</OEMDRO185>
<OEMLED185>0</OEMLED185>
<OEMDRO186>0.</OEMDRO186>
<OEMLED186>0</OEMLED186>
<OEMDRO187>0.</OEMDRO187>
<OEMLED187>0</OEMLED187>
<OEMDRO188>0.</OEMDRO188>
<OEMLED188>0</OEMLED188>
<OEMDRO189>0.</OEMDRO189>
<OEMLED189>0</OEMLED189>
<OEMDRO190>0.</OEMDRO190>
<OEMLED190>0</OEMLED190>
<OEMDRO191>0.</OEMDRO191>
<OEMLED191>0</OEMLED191>
<OEMDRO192>0.</OEMDRO192>
<OEMLED192>0</OEMLED192>
<OEMDRO193>0.</OEMDRO193>
<OEMLED193>0</OEMLED193>
<OEMDRO194>0.</OEMDRO194>
<OEMLED194>0</OEMLED194>
<OEMDRO195>0.</OEMDRO195>
<OEMLED195>0</OEMLED195>
<OEMDRO196>0.</OEMDRO196>
<OEMLED196>0</OEMLED196>
<OEMDRO197>0.</OEMDRO197>
<OEMLED197>0</OEMLED197>
<OEMDRO198>0.</OEMDRO198>
<OEMLED198>0</OEMLED198>
<OEMDRO199>0.</OEMDRO199>
<OEMLED199>0</OEMLED199>
<OEMDRO200>0.</OEMDRO200>
<OEMLED200>0</OEMLED200>
<OEMDRO201>0.</OEMDRO201>
<OEMLED201>0</OEMLED201>
<OEMDRO202>0.</OEMDRO202>
<OEMLED202>0</OEMLED202>
<OEMDRO203>0.</OEMDRO203>
<OEMLED203>0</OEMLED203>
<OEMDRO204>0.</OEMDRO204>
<OEMLED204>0</OEMLED204>
<OEMDRO205>0.</OEMDRO205>
<OEMLED205>0</OEMLED205>
<OEMDRO206>0.</OEMDRO206>
<OEMLED206>0</OEMLED206>
<OEMDRO207>0.</OEMDRO207>
<OEMLED207>0</OEMLED207>
<OEMDRO208>0.</OEMDRO208>
<OEMLED208>0</OEMLED208>
<OEMDRO209>0.</OEMDRO209>
<OEMLED209>0</OEMLED209>
<OEMDRO210>0.</OEMDRO210>
<OEMLED210>0</OEMLED210>
<OEMDRO211>0.</OEMDRO211>
<OEMLED211>0</OEMLED211>
<OEMDRO212>0.</OEMDRO212>
<OEMLED212>0</OEMLED212>
<OEMDRO213>0.</OEMDRO213>
<OEMLED213>0</OEMLED213>
<OEMDRO214>0.</OEMDRO214>
<OEMLED214>0</OEMLED214>
<OEMDRO215>0.</OEMDRO215>
<OEMLED215>0</OEMLED215>
<OEMDRO216>0.</OEMDRO216>
<OEMLED216>0</OEMLED216>
<OEMDRO217>0.</OEMDRO217>
<OEMLED217>0</OEMLED217>
<OEMDRO218>0.</OEMDRO218>
<OEMLED218>0</OEMLED218>
<OEMDRO219>0.</OEMDRO219>
<OEMLED219>0</OEMLED219>
<OEMDRO220>0.</OEMDRO220>
<OEMLED220>0</OEMLED220>
<OEMDRO221>0.</OEMDRO221>
<OEMLED221>0</OEMLED221>
<OEMDRO222>0.</OEMDRO222>
<OEMLED222>0</OEMLED222>
<OEMDRO223>0.</OEMDRO223>
<OEMLED223>0</OEMLED223>
<OEMDRO224>0.</OEMDRO224>
<OEMLED224>0</OEMLED224>
<OEMDRO225>0.</OEMDRO225>
<OEMLED225>0</OEMLED225>
<OEMDRO226>0.</OEMDRO226>
<OEMLED226>0</OEMLED226>
<OEMDRO227>0.</OEMDRO227>
<OEMLED227>0</OEMLED227>
<OEMDRO228>0.</OEMDRO228>
<OEMLED228>0</OEMLED228>
<OEMDRO229>0.</OEMDRO229>
<OEMLED229>0</OEMLED229>
<OEMDRO230>0.</OEMDRO230>
<OEMLED230>0</OEMLED230>
<OEMDRO231>0.</OEMDRO231>
<OEMLED231>0</OEMLED231>
<OEMDRO232>0.</OEMDRO232>
<OEMLED232>0</OEMLED232>
<OEMDRO233>0.</OEMDRO233>
<OEMLED233>0</OEMLED233>
<OEMDRO234>0.</OEMDRO234>
<OEMLED234>0</OEMLED234>
<OEMDRO235>0.</OEMDRO235>
<OEMLED235>0</OEMLED235>
<OEMDRO236>0.</OEMDRO236>
<OEMLED236>0</OEMLED236>
<OEMDRO237>0.</OEMDRO237>
<OEMLED237>0</OEMLED237>
<OEMDRO238>0.</OEMDRO238>
<OEMLED238>0</OEMLED238>
<OEMDRO239>0.</OEMDRO239>
<OEMLED239>0</OEMLED239>
<OEMDRO240>0.</OEMDRO240>
<OEMLED240>0</OEMLED240>
<OEMDRO241>0.</OEMDRO241>
<OEMLED241>0</OEMLED241>
<OEMDRO242>0.</OEMDRO242>
<OEMLED242>0</OEMLED242>
<OEMDRO243>0.</OEMDRO243>
<OEMLED243>0</OEMLED243>
<OEMDRO244>0.</OEMDRO244>
<OEMLED244>0</OEMLED244>
<OEMDRO245>0.</OEMDRO245>
<OEMLED245>0</OEMLED245>
<OEMDRO246>0.</OEMDRO246>
<OEMLED246>0</OEMLED246>
<OEMDRO247>0.</OEMDRO247>
<OEMLED247>0</OEMLED247>
<OEMDRO248>0.</OEMDRO248>
<OEMLED248>0</OEMLED248>
<OEMDRO249>0.</OEMDRO249>
<OEMLED249>0</OEMLED249>
<OEMDRO250>0.</OEMDRO250>
<OEMLED250>0</OEMLED250>
<OEMDRO251>0.</OEMDRO251>
<OEMLED251>0</OEMLED251>
<OEMDRO252>0.</OEMDRO252>
<OEMLED252>0</OEMLED252>
<OEMDRO253>0.</OEMDRO253>
<OEMLED253>0</OEMLED253>
<OEMDRO254>0.</OEMDRO254>
<OEMLED254>0</OEMLED254>
<OEMDRO255>0.</OEMDRO255>
<OEMLED255>0</OEMLED255>
<OEMDRO256>0.</OEMDRO256>
<OEMLED256>0</OEMLED256>
<OEMDRO257>0.</OEMDRO257>
<OEMLED257>0</OEMLED257>
<OEMDRO258>0.</OEMDRO258>
<OEMLED258>0</OEMLED258>
<OEMDRO259>0.</OEMDRO259>
<OEMLED259>0</OEMLED259>
<OEMDRO260>0.</OEMDRO260>
<OEMLED260>0</OEMLED260>
<OEMDRO261>0.</OEMDRO261>
<OEMLED261>0</OEMLED261>
<OEMDRO262>0.</OEMDRO262>
<OEMLED262>0</OEMLED262>
<OEMDRO263>0.</OEMDRO263>
<OEMLED263>0</OEMLED263>
<OEMDRO264>0.</OEMDRO264>
<OEMLED264>0</OEMLED264>
<OEMDRO265>0.</OEMDRO265>
<OEMLED265>0</OEMLED265>
<OEMDRO266>0.</OEMDRO266>
<OEMLED266>0</OEMLED266>
<OEMDRO267>0.</OEMDRO267>
<OEMLED267>0</OEMLED267>
<OEMDRO268>0.</OEMDRO268>
<OEMLED268>0</OEMLED268>
<OEMDRO269>0.</OEMDRO269>
<OEMLED269>0</OEMLED269>
<OEMDRO270>0.</OEMDRO270>
<OEMLED270>0</OEMLED270>
<OEMDRO271>0.</OEMDRO271>
<OEMLED271>0</OEMLED271>
<OEMDRO272>0.</OEMDRO272>
<OEMLED272>0</OEMLED272>
<OEMDRO273>0.</OEMDRO273>
<OEMLED273>0</OEMLED273>
<OEMDRO274>0.</OEMDRO274>
<OEMLED274>0</OEMLED274>
<OEMDRO275>0.</OEMDRO275>
<OEMLED275>0</OEMLED275>
<OEMDRO276>0.</OEMDRO276>
<OEMLED276>0</OEMLED276>
<OEMDRO277>0.</OEMDRO277>
<OEMLED277>0</OEMLED277>
<OEMDRO278>0.</OEMDRO278>
<OEMLED278>0</OEMLED278>
<OEMDRO279>0.</OEMDRO279>
<OEMLED279>0</OEMLED279>
<OEMDRO280>0.</OEMDRO280>
<OEMLED280>0</OEMLED280>
<OEMDRO281>0.</OEMDRO281>
<OEMLED281>0</OEMLED281>
<OEMDRO282>0.</OEMDRO282>
<OEMLED282>0</OEMLED282>
<OEMDRO283>0.</OEMDRO283>
<OEMLED283>0</OEMLED283>
<OEMDRO284>0.</OEMDRO284>
<OEMLED284>0</OEMLED284>
<OEMDRO285>0.</OEMDRO285>
<OEMLED285>0</OEMLED285>
<OEMDRO286>0.</OEMDRO286>
<OEMLED286>0</OEMLED286>
<OEMDRO287>0.</OEMDRO287>
<OEMLED287>0</OEMLED287>
<OEMDRO288>0.</OEMDRO288>
<OEMLED288>0</OEMLED288>
<OEMDRO289>0.</OEMDRO289>
<OEMLED289>0</OEMLED289>
<OEMDRO290>0.</OEMDRO290>
<OEMLED290>0</OEMLED290>
<OEMDRO291>0.</OEMDRO291>
<OEMLED291>0</OEMLED291>
<OEMDRO292>0.</OEMDRO292>
<OEMLED292>0</OEMLED292>
<OEMDRO293>0.</OEMDRO293>
<OEMLED293>0</OEMLED293>
<OEMDRO294>0.</OEMDRO294>
<OEMLED294>0</OEMLED294>
<OEMDRO295>0.</OEMDRO295>
<OEMLED295>0</OEMLED295>
<OEMDRO296>0.</OEMDRO296>
<OEMLED296>0</OEMLED296>
<OEMDRO297>0.</OEMDRO297>
<OEMLED297>0</OEMLED297>
<OEMDRO298>0.</OEMDRO298>
<OEMLED298>0</OEMLED298>
<OEMDRO299>0.</OEMDRO299>
<OEMLED299>0</OEMLED299>
<OEMDRO2100>0.</OEMDRO2100>
<OEMLED2100>0</OEMLED2100>
<OEMDRO2101>0.</OEMDRO2101>
<OEMLED2101>0</OEMLED2101>
<OEMDRO2102>0.</OEMDRO2102>
<OEMLED2102>0</OEMLED2102>
<OEMDRO2103>0.</OEMDRO2103>
<OEMLED2103>0</OEMLED2103>
<OEMDRO2104>0.</OEMDRO2104>
<OEMLED2104>0</OEMLED2104>
<OEMDRO2105>0.</OEMDRO2105>
<OEMLED2105>0</OEMLED2105>
<OEMDRO2106>0.</OEMDRO2106>
<OEMLED2106>0</OEMLED2106>
<OEMDRO2107>0.</OEMDRO2107>
<OEMLED2107>0</OEMLED2107>
<OEMDRO2108>0.</OEMDRO2108>
<OEMLED2108>0</OEMLED2108>
<OEMDRO2109>0.</OEMDRO2109>
<OEMLED2109>0</OEMLED2109>
<OEMDRO2110>0.</OEMDRO2110>
<OEMLED2110>0</OEMLED2110>
<OEMDRO2111>0.</OEMDRO2111>
<OEMLED2111>0</OEMLED2111>
<OEMDRO2112>0.</OEMDRO2112>
<OEMLED2112>0</OEMLED2112>
<OEMDRO2113>0.</OEMDRO2113>
<OEMLED2113>0</OEMLED2113>
<OEMDRO2114>0.</OEMDRO2114>
<OEMLED2114>0</OEMLED2114>
<OEMDRO2115>0.</OEMDRO2115>
<OEMLED2115>0</OEMLED2115>
<OEMDRO2116>0.</OEMDRO2116>
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
1.e-002
0.1
1.
0.2
0.
0.
0.
1.
45.
0.
0.
0.
0.
1.
0.1
1.e-002
1.e-003
1.e-004
1.
0.1
1.e-002
1.e-003
1.e-004
20.
5.e-002
1518
1518
129516
0
0
0
0
0
0
0
0
0
0
0
0
10.
50.
3037.223606
10.
50.
3037.223606
3
0
3
10.
50.
3037.223606
1.
30.
64758.10775
1
1
1
1
0
0
0
1
6
0
0
0
0
1
6
0
0
0
1
1
6
1
0
0
0
1
3
1
0
0
0
1
3
1
0
0
1
1
3
1
0
0
0
1
5
1
0
0
0
1
5
1
0
0
1
1
5
1
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
1
5
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
1
1
1
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
1
1
2
0
2000
1
1
0
0
0
G80
0
1
*.tap
D:\Mach3\GCode\4 linetest21.tap
D:\Mach3\GCode\1xW circle.tap
D:\Mach3\GCode\48 inch cut off.tap
D:\Mach3\GCode\whitesafety final 47.tap
D:\Mach3\GCode\pistol pete 24.tap
D:\Mach3\GCode\OU1x1u.tap
D:\Mach3\GCode\football ou.tap
D:\Mach3\GCode\deerwelcome.tap
D:\Mach3\GCode\4 linetest.tap
D:\Mach3\GCode\4 linetest2.tap
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
2
1
0
0
2
2
0
0
2
3
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
1.000000
0
0
0
0
0
1.000000
0
0
0
0
0
1.000000
0
0
0
0
0
1.000000
0
0
0
0
0
1.000000
0
0
0
0
0
1.000000
0
0
0
0
0
1.000000
0
0
0
0
0
0
50
50
50
0
0
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0
0
0.
0.
0.
0.
0.
0.
0.
0
</Preferences>
Novusun-Novusun-PlugIn-Ver-3.0b
1
450
3000
1
0
0
0
0
0
0
1178909
255
16777215
0
0
0
0
0.5
2.e-003
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
1
1
1
0
1
1
500
100
50
400
0
1
0
</profile>
Is this what you need to look at
Hi there mate, i know this is an old thread but i’m having the same problem with nvem controller, the plasma turn on in travel and it not finishes the cut.Rcmcustoms wrote: ↑Mon Sep 28, 2020 9:20 am Thanks for your help. I was able to modify the commands in the post processor to make it do what I want each time I run post processor threw sheetcam. Added couple dwells here and there and also added another line to have the computer turn on and off my exhaust fans for the table.
Could you please show me how to edit the post to eliminate this problem?
Best regards.
I know its too late but i had the same problem with the NVEM controller. i did everything without success, the torch turns on before cutting and also the cutting never ends so i always had a not finishi cut.Rcmcustoms wrote: ↑Wed Sep 02, 2020 12:24 pm Good morning. I have a home built CNC Plasma table running MACH3. Running a “cheap” NVCM6V2.1 usb card. I got all the axis working and everything seams to be working right. I load a program and looks like the unit travels the XYZ axis like it is suppose to. Problem I am having is during travel on the axis to get to any pierce point, the program turns on the torch before it gets to any pierce point. Does anyone know how to fix this?
Well, last night i couldnt sleep thinking about it and i soon as i get off the bed i went to the workshop and i open sheetcam then i upload my drawing then to machine tab, post processor and i selected mach3 plasma with scriber and THC. “I installed a Z floating head” so i put my switch offset and what i did was put 0 in the reference so the torch always has to z floating every time he moves to cut the next part. Then in mach3 in PINS AND PORTS i went to spindle TAB and enable SPINDLE with PWM. Frecuency base 5 and pwm 5% the. In CCW SPINDLE DOWN a put 1.5 seconds and now its working just perfect. I thought a lot of times to get a hammer and hit the NVEM controller. So now the plasma its working with Z floating.
Well that is interesting information and great news for you! Hopefully this info will get to the OP and solve those issues also. Thanks for posting this solution.
