Pierce count
Pierce count
So the other day my pierce count on mach 3 quit counting. Anyone know what i need too do too get it turned back on?
Re: Pierce count
Could you be thinking about the pierce count in the SheetCam Job report??
Re: Pierce count
Na man i have a live pierce count in mach 3 since day 1 and for some reason it randomly dost work for like a week now. Look right in the middle of the pic where it says reset pierces, next to that it normally tells me what im atacourtjester wrote: ↑Tue Aug 25, 2020 5:04 pm Could you be thinking about the pierce count in the SheetCam Job report??
Re: Pierce count
It looks like a revised screen for Mach 3 (non-standard) could be a macro got messed up. If you have an original software backup you may try reloading it but that may mess up you setting. On your hard drive you may have a backup (xmlbacks files) In Mach 3 folder under xmlbackups folder. Any time you make changes Mach 3 makes a new backup with the info before the change, you can change the extension on the backup file and copy it into the Mach 3 folder to see if that helps bring it back.
