P80 torch new custom consumables available .9mm and 1.0mm
Information on plasma cutting nozzles, electrodes, and other consumables.
53hudson
Post by 53hudson »
The P 80 torch is used on Everlast lotos and numerous other makes. I have in stock Top quality .9 mm and 1.0 mm tips. These give your machine more potential and versatility with the ability to use lower amperage and get a thinner kerf. especially in lighter gauge materials. Use with your standard electrode. Only 400 available in each size. US $2.50 per tip in lots of 20. Plus cost of mail from Canada. These are not available anywhere else in the world as they were custom made for me. interested? PM me. paypal only.
Re: P80 torch new custom consumables available .9mm and 1.0mm
Are you referring to the nozzle? What about the swirl ring? Do you supply those for fine cut as well?
53hudson
Post by 53hudson »
Thanks for your interest. The P80 torch does not use a swirl ring It only has an electrode and a Nozzle/Tip. I am referring to the tip/nozzle only for this style of torch. These are common to import machines such as Lotos. Everlast Cut 80 etc. They are generally only available in 1.1 orifice size and up. But in lighter gauges especially a finer tip would be beneficial.
Thanks for the clarification Hudson. I have a friend with the Everlast model and I will let him know.
Aluminartco
Post by Aluminartco »
I am interested I live in Canada quebec
Return to “Plasma Consumables”
