Getting rid of dross or slag the easy way
One can last about 4 8ftx 4ft sheets of metal
you can get it at a weld supply store.
After seeing the results you won't use muriatic acid again.
A can cost about $6.00.
You will be amazed.
Very little if any clean up
Jim
Re: Getting rid of dross or slag the easy way
Do you have a water table with this process.
No I don't. Although it probably wouldn't hurt to give it a try. Only out $6.00.
If you do try it let me know if it works for you.
Jim
Jim
I have a few cans of anti spatter spray. Not sure if it will wash off or not. I will try it.
