I am still trying to find what would make my old home-built machine run a little better. Here are my current settings:
I am still getting some corners not quite square on some internal and external cuts. What do I need to do to sharpen up those corners without making the machine go back to hitting every node and running poorly? Can someone with a dialed in machine post up your settings screenshot? Thanks All! Just trying to fix years worth of nagging problems with my machine.
CV Settings compilation - post up what works for you?
- Nacs Fab
G540 with LCTHC by candcnc
all built... by me...
Re: CV Settings compilation - post up what works for you?
stop CV on angle > 62º?
why?
why?
- Nacs Fab
Robertspark what setting would you recommend? It’s not cutting right so that could be the issue.
https://www.google.com/url?sa=t&source= ... ef9mRIyb8V
I would try it on 180 degrees, that way it should be turned off and fly around the corners, otherwise... Try 90 degrees as per manual link above
I would also turn ON plasma mode
What is your steps per unit setting? (For each axis)
What is your acceleration setting? (for each axis)
- Nacs Fab
I have also never messed with my motor tuning since getting the machine up and running.
- SeanP
These are my settings, works well for me, damn good corners up to 6000mm/min I don't run any faster than that for my cutting.
I have messed plenty with motor setup and that seems about max for mine before loosing steps, my motors are 3.75:1 reduction I think.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
The machine is running at about 9kHz (which is good, because it's nice and low, think big chunky steps [the G540 can handle up to 200khz, so you are well within the drives capabilities]).
2716 steps / inch x 200 steps per minuite / 60 (convert pulses / min to pulses per sec... i.e. Hz)
your acceleration is very low (16 inch / sec / sec)..... the "target" number that has been mentioned before is ~ 0.3G (~116"/sec/sec)
have you tried to increase your acceleration to maybe double (32 in/s/sec)?
I don't know what feedrate / material you are cutting but your maximum feedrate is 200"/min (~5080mm/min) [which is not very high]
but lets say your feedrate is 200"/min and the acceleration is 16 in/s/s
the smallest arc you can cut before your machine HAS to slow its velocity is 0.7" radius.
So if you are trying to do very small detail at 200"/min then this will not do a lot of detail for you
If you are able to double the acceleration to 32"/s/sec.... then the smallest arc you cn cut will now be 1/2 at 0.35" radius....
SeanP who just posted his number has a machine travelling a LOT faster than you.....
maximum velocity of 492"/min (more than double your's)
but much more critically to plasma is his acceleration is 88.6"/s/s.... i.e. 5.5 times yours at 16"/s/s...... he will obtain much sharper corners.......
