Nashville is full but we have another opportunity for you coming up April 4-6 in Tulsa, OK! Cost is $465 per person and we have a group rate of $105 per night at the Hilton Garden Inn.
The first 2 days of our workshops focus on Design Edge software specifically as it is used in plasma cutting. Attendees will start with settings; we will develop a full understanding of what each individual choice does, how it applies to your work, and when you might want to change it. We will spend time with each of the drawing and edit tools and the coordinate system so you can hone your skill to produce great cuts in metal whether it be for art or dimensioned parts.
A portion of the second day will be spent learning about the wiring and mechanics of the table itself which will come in handy should you need to troubleshoot problems with your machine! Then instruction will shift to an in-depth look at the powerful CAD capabilities in Design Edge and how to use them in your drawings to produce a top quality file that will give you better cuts and a top notch finished product. We will work on projects together to go from a picture to a cut ready file.
On the final day until lunch, we will build on the information we’ve covered and learn how tools can be used in combination, reference points can be established, and how to get the most out of your Advanced Design software. If you want to Make Money in Metal Art or Draw Dimensioned Parts Fast then this workshop is for you! After lunch on Saturday I will continue to help any that want to stay and practice or try new things but there won’t be any new material presented other than what comes up in discussion so if you need to go or are ready to call it a day, that will be at your leisure.
This class is also approaching half full and the next open class may not be until September in Vegas so don't miss it if you've been waiting! (There MAY be an additional class in June, location yet to be determined.)
Register for Tulsa Workshop Here
Design Edge Workshop - Nashville & Tulsa Info
- rdj357
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
