Tube Notcher
All topics related to bending, forming, notching, drilling, saw cutting, etc.
TrinityFabworks
Tube Notcher
Post by TrinityFabworks »
Just wondered if anyone has every made a tubing notcher like the Baileigh TN-250? Seems like it wouldn't be that bad using the plasma table to make something similar. If no one has one already made, I will try to get one drawn up and prototyped over the next month or so. I'm not going to make a direct copy, I really just like how it clamps the tubing! I will probably just use some cheaper, large bearing blocks off of amazon that I have lying around, and some scrap material. I just figured that at $795, it would be worth while to make one.
Re: Tube Notcher
Here is a DIY type Chuck that may give you the concept for the adjustable jaws used on the tool you are wanting to build.
http://ravenview.com/blog/2010/10/17/ho ... rth-chuck/
TrinityFabworks
Re: Tube Notcher
krackermike
Re: Tube Notcher
Post by krackermike »
I love creating good low cost alternatives to the big boys equip they over price. I have made a tube knotcher out of a central machine combo lathe mill. They can be bought on the cheap. Machine a vice down to center line of late with a v block vise..will always keep whatever size tube centered. Then go to rural king and get a few 7/8 top link pins..7 inches long or so..you will use to build the arbor for the hole saws face hole saws and weld true. The hole key is in the arbor..this method will not flex at all and cope pipe like its nobodys business...all for under 600 bucks or so....the Baileigh machine is thousands no to mention the rapid cut end mill they use...Im a machinist, trust me..message me and I will send pics if interested..-----Kracker
TrinityFabworks
Re: Tube Notcher
Thanks, I will send you a dm soon! Rural king has been in my hometown for 2 years now, and its an awesome store! Everything is so cheap affordable, and decent quality. It is like Cabelas, and tractor supply had a baby
TrinityFabworks
Re: Tube Notcher
^ oops, I guess cheap and affordable is kind of redundant.
Return to “Metal Bending, Rolling, Notching, Drilling, Saw Cutting”
