3 D Printed diamond scribe holder
Here is a video of a 3 D printed holder for a Diamond scribe I made for my table. This plaque is 3" X 5" on Aluminum.
https://youtu.be/-C48ROJ-5KQ
Re: 3 D Printed diamond scribe holder
Here is a sample for a serial number plate 2.5" X .960" on cold rolled steel.
That looks really good, may have to get me one of the scribes
Mikw
Mikw
Very nice! I've got the easysciber diamond scribe and have made some pretty cool things with it. Awesome you 3d printed your own tool holder!!!
Thanks Just have all the fun I can, buying a 3D printer has helped me learn how to do 3D drawing. I have posted other things I have developed and printed for my Plasma/ router table. I will pass along the files if a member would like to make their own or build one for them.
- SeanP
That's a grand job there Tom!
Guess hot rolled is a no no for those scribes?
That mill scale is tough stuff!
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
Thanks I have not tried hot rolled
Maybe another member that has an easy scribe could reply.
Thanks for the file, I may give it a go cheers
PM me with your email address I cannot PM them to you here, these will be the stl files, I have a Tevo Tarantula and the G-codes are configured with a slicer program called ideamaker for that printer. I could also sent the G-code if you want. The short ones are a Drag Knife
Those images are much more helpful.
Thought I'd spotted them here: https://www.thingiverse.com/thing:3340487
yes that is my posting of the item.
Here are the linear bearing I used you may need another auction to get them in the UK.
https://www.ebay.com/itm/6pcs-LM8UU-8mm ... 1438.l2649
and the chrome shafts again shipper to the UK
https://www.ebay.com/itm/8mm-x-1000mm-L ... 2749.l2649
The screw holes in the mounts are set for 10-32 thread don't know the metric size. I press the bearings in first then slide that rods in and press them in the top then the bottom so the distance between the rods is maintained. I use a vice to do this. Cutting the rods to length I use a cutoff wheel as they are very hard.
Thanks, I've been using these igus ones as they seem to have better support and less play than the bearing ones
https://www.ebay.co.uk/itm/3D-Printer-S ... 1571607189
You will need 4, 2 on each side
I've had a CR-10 for about a year now. This may need to be it's first project!
I have used mine for many projects very handy tool to have
- East German
Thanks Tom
Load from Thingi
Peter
Load from Thingi
Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
Hello,acourtjester wrote: ↑Mon Jan 07, 2019 9:29 am Thanks Just have all the fun I can, buying a 3D printer has helped me learn how to do 3D drawing. I have posted other things I have developed and printed for my Plasma/ router table. I will pass along the files if a member would like to make their own or build one for them.
I am new to the forum and cant see how to PM you yet am interested in the drag knife and scriber assemblies. I just got a 4x8 Wright CNC table and need to get some projects done asap.
thanks!
Josh
This is what you need to do to send a PM to a member
- Nacs Fab
Tom, what diamond scribe are you using? I may have to print some up! Thanks for the Share!!
G540 with LCTHC by candcnc
all built... by me...
I have use a few different ones it seems the best is the one from "Easy Scribe" they sell a replacement tip. I have also used a diamond tipped used for grinding wheel dressing, they do work and are cheaper but the angle of the tip is not as sharp. I have found others on eBay that could work too. https://www.ebay.com/itm/RDZ-1-8-60-CNC ... 1438.l2649 But these are the same price of the Easy Scribe replacement tip
