Hello, I am wanting to get into plasma cutting for myself. Back 35 years ago I did fabrication in a copper mine. Then got into the electrical trade. I enjoy building with metal for my needs. I know how to use a ox acc torch well. But have never used a plasma cutter. I have an itch to buy. I would use the cutter mostly 1/4” stock. But working with tractor implements I sometimes cut 1/2”. What I think I would mostly use this for is making reactive steel targets using 1/4 and 3/8 stock. I wonder if I will be happy with freehand cuts? So my idea is buy a Hypertherm 45 with the thought of being able to expand to a table if I ever want one. With the information given should I buy a unit that is cpc plug ready or buy the 45xp without the cpc then expand if I ever need it? I am not brand loyal but buy top quality tools is the only reason I thought about the 45xp
Thanks, Jim
45xp
Re: 45xp
Freehand cutting is tough to do well but making some templates to "trace" around with the torch is easy and will make repeat cuts much easier.
I would buy your plasma without the cpc port for now, it's very easy to install after the fact and in many cases you don;t even need it unless your table won't accept a raw voltage signal for the height control.
I certainly recommend the Hypertherm brand. My Powermax 65 has been bulletproof!
