Angel Fish oval background
- kgc1031
I believe I found This Angel fish on PS and wanted to share my work with the fish. What I have noticed about angel fish, I cant keep them on the shelf. They are one of my biggest sellers.
Re: Angel Fish oval background
very nice thanks
Thanks very nice
- Larry83301
Very nice, thanks for sharing!
- kgc1031
Thank You!
acourtjester wrote:very nice thanks
- kgc1031
Metal Works wrote:Thanks very nice
- kgc1031
Thank YOU!
Larry83301 wrote:Very nice, thanks for sharing!
Thanks for the share, very nice
Precision Plasma Patriot 4X8, water table, Price THC, UC 400ETH, Floating head
Hypertherm 45XP - Machine torch
UCCNC, Sheetcam, Inkscape/Corel X5
Thanks for the fish!
- steel 35
love the oval, Thanks for sharing!
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
That is really nice. Love Angels, thanks for sharing!
Thanks for the share.
Peter
Peter
do you have this in an svg? when I convert with convertio it comes out all messed up. TIA
Does this svg work for you?Gcf6203 wrote:do you have this in an svg? when I convert with convertio it comes out all messed up. TIA
perfect, thanks plasmanewbie! what program did you use to convert? I tried opening in inkscape also but it wouldn't open the dxf...still trying to figure this out so I don't have to ask all the time!
Your welcome. I used CorelDraw X8, just opened the dxf and saved as a svg for you. It could be a newer version of dxf that Inkscape is unable to open. I am not familiar with Inkscape but I believe it is free and with that likley come some limitations and not up to date with latest dxf versions.
im using corel x5 and for some reason it wont open dxf
- david jordan
Thank you.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
very nice thank you
thx for the share
Thanks. Very nice.
Hi, thanks for the great share. I use the trial version of Qcad to open dxf files then hit File-quick SVG export and it saves it as SVG which I can usually open in Inkscape, occasionally it doesn't work probably depends on what program the original dxf was created in.
Thanks again,
Perry
Thanks again,
Perry
Thanks for sharing!
Thank You
