help on holes
gamble
help on holes
Post by gamble »
I think the anti back lash nuts are in need of being replaced. How can I tell for certain if it's the ones on the X or Y the axis that need to be replaced? Rathe not replace ones that don't need to be replaced for now.
Torchmate 2x2 - Flashcut
Powermax 45 - Machine torch
Taig CNC Mill - Flashcut
Razorweld Distributor
weldguy
Re: help on holes
Post by weldguy »
Use your calipers to measure which direction the circle is out of round on and that will be the axis that needs the work I assume. From the picture it looks like left to right is narrower than bottom to top. Good luck.
