Fajita cooker flat grill
- Ironken
Re: Fajita cooker flat grill
I planned on using 3/16.
- otisa2007
i build these out of 10ga when designing anything like this i use qcad for the angled top i got the bottom dimension then decided what the top length needed to be and drew them off the centerlines then connect the angle its a crude method but works and i don't have to figure the thickness of the metal knowing that the inside of the metal will meet correctly hope this helps a little
- Ironken
otisa2007 wrote: ↑Sat May 11, 2019 5:33 pm i build these out of 10ga when designing anything like this i use qcad for the angled top i got the bottom dimension then decided what the top length needed to be and drew them off the centerlines then connect the angle its a crude method but works and i don't have to figure the thickness of the metal knowing that the inside of the metal will meet correctly hope this helps a little
Thank you. I will take a chop at it your way in Draftsight.
- Ironken
I found a better solution for myself......try to learn fusion 360. I should be pounding these out in mass quantity in about 2 years after I figure fusion out.......
Fusion can be tough but there are lots of videos. Every problem/question I have ever had in Fusion had been solved by a quick video I found with a Google search.
- Ironken
Thanks Newbie. I have been aksing the all knowing Googler Fusion questions and just as you said....there is always answer. Pretty cool stuff once you get going on it.
What does everyone do to treat the cooking surface. I'm definitely going to try and get one of these together.
- otisa2007
I treat mine just like castiron get them good and hot rub some oil into them do my cooking and i dont do any cleaning on it till next time i get ready to use it the two i have of my own i haven't had any rust problems do the same with my grill tops they sit out in the weather most of the time i use a scraper to clean them off when i go to use them and some fresh oil so far seems to work
Nice flat top! Thanks for the share!
I milled out a flat top to use on a 'spare' grill I had.
