Parts are being cut in a different spot than where they are nested?
Anyone ever have this problem? I have everything nested where I want it in sheet cam. Set up my tool paths and create a g code. Everything looks fine. Upload it into mach 3 still looks great. Hit start and it took 3 parts and moved them onto other already cut parts. It only did it on 1 section of the sheet. Everything else cut like it was supposed to where it was supposed to. The 3 pieces it messed up were all off by different measurements also. And the sheet was never moved. Any help would be greatly appreciated.
Re: Parts are being cut in a different spot than where they are nested?
You probably have multiple images sitting on top and it cutting. Now if its different parts (shapes ) then its got to be in the file.
