Hey Guys,
Not a total tech guy here but I can operate the systems. Just not good at troubleshooting software issues....
I am not seeing the G Code load up in Mach 3 correctly after I chose the program. It loads up a bunch of default lines but nothing like it has for 3 years.
I attached a pic of the screen of the bits loaded up.
Super busy time of the year and Mach chooses this time to play hooky......
Any advice???
Won't load G Code
Won't load G Code
Brew Worx.
Blue Frog Metal Works
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
Mach 3, SheetCAM, Solid Edge 2D, Solid Works 3D, CREO, Inkscape, and a few cobb webs
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
Re: Won't load G Code
More Info.
I wrote a new program and thought it was the new part i was trying to make. After a few attempts to redo the same work, I tried a tried and true file I have made a dozen time. same result.
text from screen attached properly this time.
Thanks for any advice in advance....
- Attachments
- Screen Shot 2017-12-12 at 6.48.09 PM.png (745.24 KiB) Viewed 762 times
Brew Worx.
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
Are you sure you opened the post processed g-code file? That text looks a lot like the SheetCam configuration settings file.
That is not G-Code. You are opening the wrong file.
I will look. I think I am loading the same .tap file as last 100 files....
Brew Worx.
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
There is nothing in that file you posted that has any G-Code in it.
