Cutting a graphic into two parts
I have a graphic that I want to cut in half so I can cut it on my plasma table. Then I can cut the two halves separatly and weld them together later. Simple way is nice for this guy
- WyoGreen
Re: Cutting a graphic into two parts
So what program are you wanting to cut it in half with? CorelDraw, Inkscape, other? A little more information would be helpful.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
- Gamelord
- 4.5 Star Member
You may be able to index your plate and cut it all out.
Torchmate CAD
Torchmate CAD
Using Inkscape
Find a place on the drawing that works for a line to run across, use the divider tool separate the two halves draw a line from one point to the other on each piece then save them as two files.
Am I missing something here
