anybody want to take a stab at tracing?
kchoghead
Post by kchoghead »
I need the top and bottom arc traced if possible
Re: anybody want to take a stab at tracing?
Another poster had suggested laying paper over thing to trace then use a scanner to load it into your computer then use Inkscape trace to convert to a DXF or SVG file. If you do that you can scale it to what ever size you want.
kchoghead
Post by kchoghead »
this is a pic that a friend sent me to see if i could cut it out... I use torchmate cad, but the scanning feature of this software does not like this.just a bunch of squiggly lines
rdj357
Post by rdj357 »
I'm trying to understand what you're after. Just the top and bottom arches with text or the whole thing?
noclinkers
Post by noclinkers »
It is a start.
BLYD Crew.dxf
kchoghead
Post by kchoghead »
Thanks a million noclinkers.. i was looking for the top and bottom with text... You nailed it...I wish i could trace like you do
noclinkers
Just practice. I am using TMCad like you are. :D
kchoghead
Post by kchoghead »
I will take that advice, knowing that you use tm cad ad have those results. most things trace pretty good but when I try to trace patches and such the lines are all over the place.
noclinkers
That came out wrong. I meant that I just practice to get to where I can use the program to do almost anything I need to.
I wasn't advising you to do anything, that is up to you.
