Helping out a local Fire Dept
sfrsdavis
Post by sfrsdavis »
I need help converting and cleaning up jpg please. This is what I have and what I get after inkscape.
Re: Helping out a local Fire Dept
There are a few things to change first use "Brightness cutoff" not "edge detection". Edge detection will give you the outside and inside of each line.
Next click on Fill and stroke under "object menu" then a menu will appear on the right, click on the X under fill this removes the inside color. Then click on stroke paint (select a color) to put color on the lines, you will see just the outlines. Then click on stroke type and then "IN" for inch size and then enter about 0.005" this is for the line width.
When you save it as DXF and unclick the "use ROBO" and "use LWPOLYLINE" so you don't get those funny connection lines ( look like spider webs) in the finished file. :(
Or save it with SVG
fire badge.dxf
(550.49 KiB) Downloaded 75 times
fire badge 1.jpg (27.33 KiB) Viewed 1073 times
hemichargersrt8
Post by hemichargersrt8 »
Here is one I did recently, maybe it will give you some ideas.
sfrsdavis
Post by sfrsdavis »
Thank you both! I am going to retry it with your steps acourtjester just so I can learn. Thanks again!!
If you really want it to pop check out what others have done with badges, making them in layers.
Using Inkscape you can break the image apart to paint them and then assemble it in layers. :D
http://www.plasmaspider.com/viewtopic.php?f=12&t=21225
http://www.plasmaspider.com/viewtopic.php?f=12&t=23594
fire badge 2.jpg (20.46 KiB) Viewed 1054 times
sfrsdavis
Post by sfrsdavis »
Can you share the DXF for those?
here you go I had to do it again as I did not save it. :lol:
fire badge apart.dxf
(521.99 KiB) Downloaded 119 times
sfrsdavis
Post by sfrsdavis »
Thanks!!!!
Return to “Inkscape”
