Here's what I'm trying to do and need advise.
I know this has been covered but I don't know how to search.
I am cuttIng a 4'x4' sign and want to space it approx 1" off the wall. The customer is going to put a light behind it.
I am looking for the kiss method (keep it simple stupid)
I'm afraid I keep overthinking it
Thanks for your help
Ethan
How to space pieces off a wall
Re: How to space pieces off a wall
Why not used key hole brackets on the back to hold it off the wall. put anchors in the wall with bolts, mount the sign with brackets over the bolts and then tighten the bolts
acourtjester wrote:Why not used key hole brackets on the back to hold it off the wall. put anchors in the wall with bolts, mount the sign with brackets over the bolts and then tighten the bolts
Thank you so much.. generally I fell in pretty quick on simple clean brackets and such.. for some reason I had such a brain fart on this one. I was wayyy overthinking it!!
Thank you so much for your help
Happy to help
