Tree of Life Infinity
- kgc1031
Plasma Spider members,
Do you know where I can get the Tree of Life Infinity in a dxf file or is there a member that would like to share theirs?
Thank you kindly,
Karen Carter
Thank you kindly,
Karen Carter
Re: Tree of Life Infinity
There is also a "tree of life curly" on here. Search it
- kgc1031
I'll search the curly. Thank You!
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
Miller 350P
Thanks for sharing.
Thank you for sharing!
Very nice.. thanks for the share
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
- kgc1031
You are the best! I'm sending you hug. Thank you so much for sharing!
- Capstone
nice file... thanks... I will never get enough time to cut all these good looking files
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
I hope this is an OK thing to do, I liked the Tree of life curly so downloaded it and then scaled it down to a size I may just fit on my table. I decided to loose a bit of detail and make it into a ring. Then started to use the file to learn how to trace images, play with nodes etc.
I have not cut yet still not sure if it will scale to my hobby machine, but here it is for a look over and bit of criticism. Still learning how to use QCAD Pro but slowly getting there. I guess the cross could be changed to what ever religious symbol you may wish for.
Adrian
Dam looks like I have some open paths, let me get back after a repair! OK now found and it seems to open and show OK to cut in Sheetcam.
Adrian
I like it! Thanks!
Awesome interpretation!! Thank you!
All it needs is a change from leaves to apples and a snake in there!
Adrian
Adrian
- david jordan
Thank You.
PlasmaCam DHC 2 4 X 4 table
Powermax 65
400amp mig welder with dc tig
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Sothbend, 5C collets
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Powermax 65
CRP Bench Top Pro
CS 6,Aspire,Mach 3
Bridgeport
Wells Index mill
16" Hendy lathe
Everlast Tig200 Amp
PL1220
Be careful where you place the snake and apples, it could get obscene in a hurry.........
Every day seems like I am re-doing something on my desk table top plasma, changing the drive, stopping water blow-back hitting the bearing surfaces etc.
So I set myself little test pieces along the way just to see how the things progress.
Well tonight I managed to get this cut 450mm diameter and a mug for scale.
I was very pleased, but a stress trying to stop tip ups getting in the way as some I could not pull out easily. It was good to see the end piece as it were.
Thanks again to sphurley for the post of the tree.
Adrian
Adrian
- kgc1031
Very nice!
Thanks for the curly file, had a customer want a name drop added to the tree of life, quick plasmaspider search and 3 hours later I have this
- kchoghead
here is the file with a open box for the name and a video on how to do it in Inkscape
https://drive.google.com/file/d/11wzCm4 ... sp=sharing
Very Nice, Thanks for sharing!
I love this tree of life and have a need for it could you share this file with the name drop with me Please?
