What post processors are you guys using? I set up a torch yesterday but I do not have a good functioning post to run it.
My plasma post touches off the work to find material height. That will not work with the oxy setup. I tried a few other posts that came with sheetcam but none seemed to function right. I am fine doing all manual z movements but I need a way to be able to move the Z up and down while running a program. Right now I can not make any manual Z adjustments while a program is running. I have a solenoid for the cut oxygen so I need the post to fire that as well.
CNC Oxy / Fuel - Mach3 / Sheetcam
- East German
Re: CNC Oxy / Fuel - Mach3 / Sheetcam
Hello,
you can make a User Button Z Axis Up and another Button Down and a User LED fore Z Axis by Hand with Mach screen:
The Code Up Button:
If (GetUserLED(1316) = 1) Then
DoOEMButton (233)
Sleep ( 500)
DoOEMButton (234)
End if
The Code Down Button:
DoOEMButton (235)
Sleep ( 400)
DoOEMButton (236)
End If
This is my setting, the output is 500 or 400 ms high and a Relais set GND to the THC Up or Down Pin.
With the sleep Time Adjust the travel distance from Z Axis.
The Button have a Hotkey U and D fore Up and Down.
You can control with the keyboard or with the gamepad with keygrabber.
Works fine every years on my Machine!
A other way is a Switch fore Up and Down!
See the picture! Regards Peter
The Code Up Button:
DoOEMButton (233)
Sleep ( 500)
DoOEMButton (234)
End if
DoOEMButton (235)
Sleep ( 400)
DoOEMButton (236)
End If
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
Thanks for the info, I've never played around with editing my Mach screens honestly I'm not even sure where to start with that. Is there a way to just use the Z in normal jog mode while running a program? That would be ideal then I can just set up a remote pendant since I was planning on doing that anyways.
- East German
Hello Bronco,
I can do that to you I'll send you the set file from Mach3.
If you are interested then I do it?!
Peter
Peter
MyPlasmCNC
Machine Torch
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
- East German
It could look like that.
Is a quick try
Peter
Is a quick try
Peter
MyPlasmCNC
Machine Torch
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
That is perfect! That button will work while a program is running?
- East German
Hello
Yes, it works. But hardware is also needed. I'll make a plan in the next few days.
Peter
Peter
MyPlasmCNC
Machine Torch
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
- East German
Hello,
A second LPT port is the best.
See the config from Output and input.
And make a Bridge from Pin2 to 12 (THC Up) and Pin 3 to 13 ( THC Down) see the Pic
Or a cheap BOB and uses the relays
The set File and Bitmap sent a PM
Regards Peter
Regards Peter
MyPlasmCNC
Machine Torch
Machine Torch
MyPlasmCNC
Machine Torch
Machine Torch
Hello Bronco,
I know this thread was long ago, your table hardware set up almost the same as mine. How about your table work ?
