It is currently Thu Jan 18, 2018 6:40 am
Looking for a wall mounted vertical sundail
Cz_apie
Postby Cz_apie » Thu Mar 02, 2017 12:40 pm
Hi
Looking for a DFX of a wall mounted vertical sundial similar to the image displayed below
Deon
Plasmacam 4x4 DHC2 Table
Design Edge 4.36 Advanced Design
Advanced Height Control
Hypertherm PM 65
Mac Afric Cut 40 Plasma
Mac Afric Mig 195
Mac Afric Tig 200A
Thermax DC 200
Fulgor Butt Welder
13" Metal Lathe-Milling Machine
Rong Fu 25 Mill
Cz_apie
Re: Wall mounted vertical sundail
Postby Cz_apie » Thu Mar 02, 2017 12:44 pm
Cz_apie wrote:Hi
Would appreciate If someone would be so kind as to share something like that please
Deon
sorry I submitted before completing request
Hypertherm PM 65
Mac Afric Mig 195
Mac Afric Tig 200A
Thermax DC 200
Fulgor Butt Welder
Rong Fu 25 Mill
Re: Looking for a wall mounted vertical sundail
Postby Larry83301 » Thu Mar 02, 2017 12:54 pm
Any Sundial you make needs to be designed for your location. Check out this site for how to make one for where you live, and then make whatever background shape you want.
https://www.sundialzone.com/en/sundial
Cz_apie
Postby Cz_apie » Thu Mar 02, 2017 1:36 pm
Larry83301 wrote:Any Sundial you make needs to be designed for your location. Check out this site for how to make one for where you live, and then make whatever background shape you want.
Thank you for that link, have been on that site before I placed my request, Tried to use the creator on that site but the design that they come up with will not work for me, totally not looking like the one on the picture. The sundial on the picture above is on a wall not more than 10 kilometers from my house, also on the same orientation line than my house, direct line east west orientation and it is extremely accurate, If everything fails, I will have to climb up against that sundial and will have to go and measure it :mrgreen: but I would rather avoid that If possible :mrgreen:
Deon
Hypertherm PM 65
Mac Afric Mig 195
Mac Afric Tig 200A
Thermax DC 200
Fulgor Butt Welder
Rong Fu 25 Mill
billphillips
Postby billphillips » Thu Mar 02, 2017 2:35 pm
first one I have seen mounted this way interesting
bill
WyoGreen
Postby WyoGreen » Thu Mar 02, 2017 8:52 pm
I suppose you could take a straight on picture of it, then measure the dia. of the outer circle. Then you could trace the picture and size it to the dia. you measured. If we assume the bricks are 8" bricks, then it looks to be a little over 40" in dia.
I can't quite figure out from the picture how the shadow is cast on the dial.
Edit: I found this on the internet - http://lifehacker.com/5668117/create-a-working-vertical-sundial-based-on-your-location
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
CNC Router table
lockeyone
Postby lockeyone » Thu Mar 02, 2017 9:08 pm
I went to this website and printed off my own for my location. After the sun came out later in the day it seemed the time was pretty close. The V in the picture gets folded upwards and casts a shadow. The wind was a bit strong today and threw the clock off a bit by pushing the tab. The paper printed as PDF which in my software could be brought into my software and enlarge it. Only thing would be the scale of the tab that casts the shadow. Still pretty cool.
Table 4'x4', BladeRunner EtherCut 620 LINUX w/CommandCNC
Hypertherm 65 CPC/RS485 Machine torch 2016
BobCad router 50"x50" MACH3 2kw spindle 2003
Shoptask Eldorado cnc MACH3, 1999
Epilog Mini 24 60watt, 2013
Vectric Aspire CoralDraw x6 SheetCam
Cz_apie
Postby Cz_apie » Fri Mar 03, 2017 7:39 am
Steve, so what you are saying is that you cannot see the metal rod sticking out from the second row of bricks from the top, directly in a vertical line above the 12 at the bottom of the dial and casting a shadow just below the 8 on the right side of the dial ? This picture were taken just after 8'o' clock in the morning. The wall is on a direct east-west line with the clock face and rod pointing to north (remember we are situated in the southern hemisphere below the Tropic of Capricorn) and that may explain it a little better I hope ?
Deon
PS your link above points to the same link previously posted by another member and that calculator totally wrong for our possition
Hypertherm PM 65
Mac Afric Mig 195
Mac Afric Tig 200A
Thermax DC 200
Fulgor Butt Welder
Rong Fu 25 Mill
Postby Larry83301 » Fri Mar 03, 2017 2:08 pm
See if this works for you. Print out the picture and see how close it comes to keeping time, only then would I cut metal. Hope it helps. :D :D
WALL SUNDIAL-A.DXF
Cz_apie
Postby Cz_apie » Sat Mar 04, 2017 11:16 am
Larry83301 wrote:See if this works for you. Print out the picture and see how close it comes to keeping time, only then would I cut metal. Hope it helps. :D :D
Larry,
I owe you "big time", exactly what I were looking for and will test and cut and post pictures back, sure it will be accurate :mrgreen:
Deon
Hypertherm PM 65
Mac Afric Mig 195
Mac Afric Tig 200A
Thermax DC 200
Fulgor Butt Welder
Rong Fu 25 Mill
Users browsing this forum: Bing [Bot], drodgers, Google Adsense [Bot], Greg_R, hemichargersrt8 and 17 guests
