convert dxf file to bmp
jbright
Post by jbright »
I'm needing advice on converting DXF files to BMP. Any help would be appreciated.
Thanks, jbright
TTS
Re: convert dxf file to bmp
Post by TTS »
I can save them as BMP from DXF using Adobe Illustrator. Do you have access to that program?
lockeyone
Post by lockeyone »
How about a screen shot or using the Windows "snipping tool". If you only need to show someone the image. That is if it fits on the screen.
Not sure what your goal is. Probably should let us know what software you do have.
Table 4'x4', BladeRunner EtherCut 620 LINUX w/CommandCNC
Hypertherm 65 CPC/RS485 Machine torch 2016
BobCad router 50"x50" MACH3 2kw spindle 2003
Shoptask Eldorado cnc MACH3, 1999
Epilog Mini 24 60watt, 2013
Vectric Aspire CoralDraw x6 SheetCam
Ok if you download the free version of Irfanview (http://www.irfanview.com/) and also get the DXF plug-in you can view DXF files by clicking on them and you can save as many file formats BMP is one.
It will change the Icons for all DXF files to a flat cat see attached to make them IDed of DXF.
