American Flag with Full Pledge
This is a cleaned and updated file for American Flag with Full Pledge. (Fixed A on bottom line and spaced letters).
This includes lean in cuts and works as is with Design Edge. The only thing you might want to do is pick your own cut path order.
I have cut this at 32" Wide in 14 Gauge and the image attached is the resulting cut.
This is PCM format for Design Edge and I cannot export as DXF so will need to rely on another member to convert and post as DXF.
Hope this is useful to some. Enjoy
Last edited by rickjamesbish on Sun Jan 22, 2017 7:24 am, edited 3 times in total.
Re: American Flag with Full Pledge
If you have downloaded the PCM or DXF prior to 1/22/07 you need to fix letter spacing and the A on the last line.
Very nice can you post it as DXF file
Will have to wait until someone with DesignEdge or other means of exporting to DXF. I have the basic version and it will not let me export.Metal Works wrote:Very nice can you post it as DXF file
Ok thank you it is very good work
here it is in dxf..zipped
great file..on right side , off the drawing, there is a line, node, cutpath that i couldnt find initially. Wouldnt allow drawing to center. finally found it. other than letter spacing in places, this is an outstanding file..GREAT WORK !!!!
Interesting I am not complaining this is a very useful file, it opens fine in Irfan-view and my CAD program. But in Inkscape there are no letters or stars. Another odd thing is the stars have lead ins but the letter do not. Other files that I have downloaded that have lead ins all elements have them. I know some software puts them in and others are added in SheetCam.
Anyway thanks to Harry for converting and original poster Rick
The stars were converted to cut paths and the rest was not. I really wanted to post it with no cut paths at all since I think its easier to edit it if needed and then convert.acourtjester wrote:Interesting I am not complaining this is a very useful file, it opens fine in Irfan-view and my CAD program. But in Inkscape there are no letters or stars. Another odd thing is the stars have lead ins but the letter do not. Other files that I have downloaded that have lead ins all elements have them. I know some software puts them in and others are added in SheetCam.
Sorry about that. So I had a path out in limbo somewhere ?harrymorley wrote:great file..on right side , off the drawing, there is a line, node, cutpath that i couldnt find initially. Wouldnt allow drawing to center. finally found it. other than letter spacing in places, this is an outstanding file..GREAT WORK !!!!
I will clean it up this evening and get spacing on letters better. I did not want to post it as "Ready to Cut" because I have not cut this one yet and if I got spacing where I thought it was ok and said it was ready then someone might get upset when a letter falls out.. LOL
yup...cut path i think or a small dot to the right of the drawing..like I said, great file..
Very nice file.. I imported to corel and cleaned up a lot of nodes and had some overlapping lines. moved a few letters. nothing maor at all.. I just haven't ran it through sheetcam yet but should be good ta go..
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
WARNING...If you downloaded the PCM or DXF for this prior to 1/22/17 you will need to fix the letter spacing on some letters and the A on the last line.
Download the PCM in the original post, which is corrected, cut and works as is in Design Edge. At most you might want to reorder the cut paths.
Looks great.
Thanks for converting this file. If you get time can you please download the file in the first post, which is now updated with fixes, and replace the file in your original post ? Im assuming your using Design Edge. If not is there some free or maybe not so expensive software I can get to so I can post DXF ? DE cost another $1000 just to get the export feature so thats not an option. Thanksharrymorley wrote:here it is in dxf..zipped
Cut and Painted.
Textured Candy Finish
Any chance someone could convert the (updated) PCM to DXF or SVG? Looks great, btw. Thanks!
Great looking flag. Thanks!
Beautiful! Thanks for sharing!
Awesome file! Thank you!
I don't know how many have cut this out but when when I looked in SheetCam I found some problems with the stars lead ins. Look at the 2 images attached and you can see the start and end points are not the same, there are over cuts which would cause a problem. I went in and removed them and then saved the file in SVG format. The A in and on the bottom line had a drop out, I copied another A and replaced it.
- little blue choo
Thank you Acourtjester. I was going to convert to SVG and fix it tomorrow but you did the work for me. I owe you one.
Rick
Rick
Rick
Arclight 9600 4x8 table
I did a little more work and grouped the stars and letters in one layer, made the lines and the outside 2 other layers and removed some other short double lines. So now you can cut the stars and letter with an inside offset and the lines no offset and the outside with outside offset.
what do you guys use for paint or is that powder coat?
