all things through Christ wall hanging
Not an original piece of artwork but a variation of what I've seen out there. one of my customers wanted this but didn't like all the cursive lettering seen in some of the others so I put this together. Thought i'd share with everyone since I've gotten some great files here and everyone is usually very helpful.
- steel 35
Re: all things through Christ wall hanging
Yep she wants it. Thanks
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
Thanks for posting
I have been unable to open the file you attached with Inkscape, TurboCad, or QCAD.
could you ro another member attach a SVG version of the file?
Thanks Tom
Thanks Tom
- steel 35
Its not SVG but I just cut it, Resize in Sheetcam (Its pretty big) and your good to go, if you cant do it elsewhere.
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
Hyp 65 duramax's
EasyScriber
Thanks Steel I was able to open that file in TurboCad.
Thank you for the file.. I scaled it down and made this for my wife for Christmas. This is out of 18 GA Stainless Steel
- rons
Thank You for the share, I did this for a friend who is having surgery great timing.
4x8 Home made with PPL Gantry
Bladder water table
Candcnc EtherCut + DTHCIV
Hypertherm PM 65 machine
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Ingersoll Rand 7.5 hp 80 gal
Harbor Ref. Dryer
Lathe, BP, 1" x 12" Cosan Miter Saw,
Bladder water table
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Harbor Ref. Dryer
thanks for sharing your completed pieces.... i'm glad someone found value in this.
Glad to know I'm not the only one using turbocadacourtjester wrote:Thanks Steel I was able to open that file in TurboCad.
Thanks for sharing! Very nice...
5x10 Dynatorch High Definition plasma table. Cuttingshop drawing program. Sigmanest nesting program. Custom fabrication and powder coating.
Whatsoever thy hand findeth to do, do it with thy might Ecclesiastes 9:10
Thanks for sharing, nice job. I loved seeing the different ways it was cut and finished. You guys are all rockstars!
Yep. Had a customer request the same phrase and complain the entire time I adjusted it. 8 or 10 versions then said he changed his mind..... Hopefully he got it and was happy.....
Nice work.
Nice work.
Brew Worx.
Blue Frog Metal Works
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
Mach 3, SheetCAM, Solid Edge 2D, Solid Works 3D, CREO, Inkscape, and a few cobb webs
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
Thank you!
This is nicely done. Thankyou
Perfect to go in my son's room
