Puerto Rico Police Badge
I'm having the hardest time with this file. Can someone please convert this to a clean vector that I could use. It would. S greatly appreciated. I don't usually have a hard time, but this has me doing a lot of work. Thank you in advance.
Melbourne, FL
- Capstone
Re: Help converting image
You forgot to upload the pic or need to shrink it to fit the forum guidelines, and technically this request should be in the File Conversion Help Wanted forum section, not the sharing section and lastly, if you put the name or description of the file you want help with in the subject line, you might get more interested people to take a look. Sorry to troll, but in the long run, everyone will be more receptive to requests if we all follow these simple steps.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
hopefuly this uploads
Melbourne, FL
- Capstone
Good luck with that...
Phil
CNC Metal Design
JD Squared 4x8
CNC Metal Design
JD Squared 4x8
I dont have time to fine tune it but here is a rough translation to .dxf. If i have more time later on i can add stencil text and smooth it out.
Ive never attached anything so let me know if its visible or not
Here is some help using inkscape and the trace "color quantization with a number about 14 colors. Then with it highlighted remove the fill and give it a stroke about 0.010" for thin lines. The break it apart under path to get each item separated so you can delete duplicate lines down to one per item.
I would make it a multi-layer with cutting the letter to be put on top of the shield and make the people separate too. If you play with the number you can change the detail of the items when you have them separate copy them to another inkscape page and work on other parts to get them better then copy them to the other page to. making the original larger helps to separate the items too.
have fun
have fun
That's about the same results that I have as well using Inkscape. Thank you for trying
Melbourne, FL
It can be done if you spend a little time on it. Here are some of the things I have assembled from a drawing. They have a background and then separate parts painted and attached to the background for a layered effect.
- RobinHillMachine
Try this one. You'll have to add the text.
- RobinHillMachine
Did the badge I posted work for you?
Anybody know how to do a DXF file single layer for the Miami hurricanes ibis ?
