Looking for some help on this one
need help with this one
- RobinHillMachine
Re: need help with this one
Do not try to cut this as is. It is a start though. You'll have to finish the file. All the lines are there. They need to be joined and all that. You should be able to make it work from here.
Sorry new here what is SVG? file i usually use DXF
Scalable Vector Graphics
Art work seems to work better in that format, they load into sheetcam the same way as DXF but use the ration 1:1 if the drawing is the size you want to cut.
- RobinHillMachine
That file is not ready for SheetCam though. It's just a start. Import it into your drawing program and finish it. I got you 3/4 of the way there.
I would like to cut 2 feet square but i would need DXF Thanks
