My 16-Foot Entry Gate
Hootville
Post by Hootville »
Well....here is my first gate project. Made this 16' single swing gate for my entry, and it was definitely a live and learn project. Drew it up in Autocad from pieces and parts of files posted on the dxf share section as well as a package I purchased from SignTorch. Lower half was cut from two 4x8 sheets of 1/8" and seamed in the center. My only regret is that I used 1/8" for the cutout when I should have used 3/16" for the added stiffness. Thinner cuts are a bit flimsy for something this size. I was trying to keep the overall weight down on the gate for the automatic opener and lighter duty 1-1/4" schedule 40 pipe frame. Total wight about 320 lbs....I will see how it holds up.
16-Foot Entry Gate.jpg (277.15 KiB) Viewed 5644 times
Hypertherm Powermax 65
4'x 8' Eagle Plasma Table
AutoCad Civil 3D
SheetCam
Mach3
Lincoln MIG
Everlast 256S Combo Arc/TIG/Plasma
Millermatic 211
KIDTech
Re: My 16-Foot Entry Gate
Post by KIDTech »
Nice looking gate, we get a lot of comments on ours at my place. It will be quite the conversation piece.
Gecko g540
Pm65 - aka game changer
Proma THC
ACAD, SheetCam, Mach3
Millermatic 211
NEW HORSE IN THE STABLE:
tnbndr
Post by tnbndr »
Nice job. Post pics after install!
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
WyoGreen
Post by WyoGreen »
Very nice gate. Now if I only had a nice entryway to deserve such a nice gate! :D
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
rons
Post by rons »
Great Work
4x8 Home made with PPL Gantry
Bladder water table
Candcnc EtherCut + DTHCIV
Hypertherm PM 65 machine
Sheetcam, Mach 3
Corel DrawX7
TurboCad 2015
211 Miller Mig
Ingersoll Rand 7.5 hp 80 gal
Harbor Ref. Dryer
Lathe, BP, 1" x 12" Cosan Miter Saw,
little blue choo
Post by little blue choo »
Very nice looking Gate hootville. Post pictures when you finish and install it. Keep up the good work.
Rick
Rick
Arclight 9600 4x8 table
Buzzard Gut
Post by Buzzard Gut »
Looks Great!
The older I get, The better it was!
Hootville
Post by Hootville »
Well, here is the gate finished in all its glory. I'm pretty happy with how it turned out with the rustic look and all. I just finished installing the gabion rock monument walls on the sides.....PITA as I had to hand stack them. All I need to do now is tie my wood pole fence back into the gabion walls and install the glass in the light boxes. I will wait until the weather warms up to install an automatic opener as I'm already tired of opening and closing this damn thing :lol:
Thanks for looking!
AutoCad Civil 3D
SheetCam
Mach3
Lincoln MIG
Millermatic 211
East German
Post by East German »
Ver very Nice!!
Regards Peter
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
MemFor
Post by MemFor »
Your gate is as impressive as your view. The art complements nature.
Binderman01
Post by Binderman01 »
how did you go about getting that patina'd look if you dont mind sharing? fabulous gate!
Hootville
Post by Hootville »
Binderman01,
Good ole rust....I sandblasted the gate down to bare metal as shown in the first photo of the post, then used a garden sprayer with a mixture of roughly 60% water, 30% pool chlorine and 10% muratic acid (pool acid) on the gate, steel casing uprights and Gabon steel mesh. Let it set overnight and sprayed off with the hose next day a few times to get a rusty even look across the whole thing. It starts rusting immediately however with the initial application. Next year I may set the rust patina with a clear coat, but might just leave as-is since it was the exact rustic look I was after.
Thanks for commenting.
AutoCad Civil 3D
SheetCam
Mach3
Lincoln MIG
Millermatic 211
boodog710
Post by boodog710 »
The gate and the view are really awesome. Nice Work. Take that picture, enlarge it and hang it in your shop. That's all the advertising you will ever need to do!
bigcreek
Post by bigcreek »
Ya that looks incredible awesome job!
Millerm9297
Post by Millerm9297 »
That is awesome outcome of your project and your gate design is truly one of kind
Pit&Boots
Post by Pit&Boots »
That is absolutely gorgeous!!
Euclid933
Post by Euclid933 »
Fantastic job.
What an entrance !!!
pine fab
Post by pine fab »
Professional and impressive, You have started my wheels turning to replace my gate!
Regards, Bryan, Retired USN Diver, in the Philippines
d2day
Post by d2day »
Nice
Mach 3
SheetCam
Corel x5 / Version 12/ Version 7
ArtCam 7.0
CNC Router
ULS Laser
4x4 Plasma Table/Hand Built
HyperTherm PowerMax 45
Cut Shop Software
LCTHC
sagreen83
Post by sagreen83 »
Gate looks awesome! How did you bend the top bar of the gate? I've pondered starting a gate project for my hunting ranch, and bending that top part has me stumped.
Scott...
Hootville
Post by Hootville »
Scott,
I actually used a HF tube roller for the job as it came with the correct die for my pipe size. Being a Civil Engineer, and having access to a large format plotter I plotted the gate to scale and laid it on the floor to use as a welding template for my internal panel design. Someone more skilled than I could have probably done without the template but it did allow me to keep running the top rail thru the tube roller until I had the right radius that matched up to my cut-outs. So far the gate has held up nicely!
AutoCad Civil 3D
SheetCam
Mach3
Lincoln MIG
Millermatic 211
