It is currently Sun Jun 24, 2018 12:18 pm
Hypertherm T30v Shielded Consumables?
Information on plasma cutting nozzles, electrodes, and other consumables.
Bigdogbro1
Postby Bigdogbro1 » Fri Aug 05, 2016 10:19 am
I thought I read somewhere that Hypertherm was creating a new 30A shielded consumable set for the PM45 type torch.
We could also use Ohmic touch off with the shielded 30A consumables
Any possibility here Jim?
mechanicalmongoose20
Re: Hypertherm T30v Shielded Consumables?
Postby mechanicalmongoose20 » Fri Aug 05, 2016 5:23 pm
Bigdogbro1 wrote:I thought I read somewhere that Hypertherm was creating a new 30A shielded consumable set for the PM45 type torch.
Now that would be killer @jimcolt
5x10 PPLLC GANTRY
PMX45
CANDCNC 620-4 OHMIC FEATHER TOUCH
VELOX Z AXIS WITH CUSTOM MOUNTS
SWAG FINGER BRAKE
ALPHATIG 200X
HOBART 210MVP
Postby jimcolt » Sun Aug 07, 2016 8:21 am
There are currently no plans for development of shielded 30 amp consumables for the existing Powermax45 style torch. Our Torch and Consumables teams are working on lower amperage cutting for future product releases. I suspect that if newer consumable technology with low amperage shielded consumables becomes available it likely will be in a different torch design......when we have more information we will announce it!
stonebriar
Postby stonebriar » Sat Nov 05, 2016 2:30 pm
This is in the PM45 manual.
A complete set of shielded consumables is shipped with the T45m machine torch. In addition, an ohmic sensing
retaining cap is available for use with the T45m shielded consumables. Unshielded consumables and the T30v
(Powermax30) 30 A consumables are also available for use with the T45m.
Would these consumables be of use for thinner gauge 14-16 material than the 45 consumables?
larrycameron44
Postby larrycameron44 » Mon Dec 19, 2016 4:33 am
Yes I have used the 30 amp consumables for the POWERMAX 45 for the last 5 years.
Good from .5mm copper to 3mm mild steel
Larry Cameron
RusticMetalArt
Return to “Plasma Consumables”
